Wideband gauge ??
Old 03-25-2016, 12:11 AM
ArtPerez805's Avatar
Wideband gauge ??
I'm sure they're is a thread about this
But I'm gonna try and install a wideband/lamda gauge.
I've never done any wiring or install like thiss...so if anyone can post a thread or their diy for me thanks👌
Old 03-26-2016, 05:22 PM
3.7L Nitrous Breathing CL
richardparker's Avatar
It's just a key on + ,a ground ,and install the sensor before the cat.
EvilVirus (04-01-2016)
Old 03-26-2016, 05:32 PM
So would that be before each pre cat?
Or at my test pipe?
Ok would that be b4 each pre cat or at my test pip
Old 04-01-2016, 05:06 PM
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
Wrong section to ask this in. You would get more responses if it was in the performance section. Ask Mods to move it
Old 04-12-2016, 11:03 PM
Duronn's Avatar
That depends if you have pre-cat deletes or not. On mine, I installed the bung and the sensor of the J-pipe, but I have free flowing pre-cat deletes. If you don't, you wanna install it before the pre-cat...hmmm...but I'm not sure where.
Old 04-15-2016, 03:40 AM
Would i be able to take out one the existing o2z and use the wideband o2?
Old 04-15-2016, 11:48 PM
Duronn's Avatar
I have no clue, I dunno if its the same size but you need the O2 sensors. Why do you need a wide band?
Old 04-16-2016, 02:02 AM
To see how its gonna be running while on nitrous ..want to monitor it
Old 04-16-2016, 04:51 AM
Duronn's Avatar
Well according to the AEM wideband instructions, you're gonna have to mount it before the precat: "For accurate readings, the sensor must be mounted before catalytic converters and/or auxiliary air pumps." If you don't have pre-cat deletes, you may wanna ask a muffler shop if they can make a hole & weld close to the O2 sensor since thats the only reasonable place.
Old 04-16-2016, 07:32 PM
I that's what im going to have to do,I'm they can
