H&R spacer debacle
H&R spacer debacle
So I’m a little bit confused by this one. I put the H&R tram+ spacers on the other day, like everyone else seems to be using, and even after seeing all the pictures and such… It looked horrible! The tires and wheels stuck out well past the body and these were 20 mm spacers. So I was very confused.
When you look at the car, you would think they were tucked under enough from the factory to make them even with the body, but I think only 10 mm is needed, I just need to find those spacers?
Or go with a wider tire. Just wanted to fill that gap a little bit and it was way overboard! Just a heads up if anyone’s considering the same. I felt like a hillbilly redneck with a Camaro. Lol no seriously.
