2021 TLX/SH-AWD/A-SPEC Spare?
I have a 19" Donut Spare, for my 2018/A-SPEC; if I upgrade to the 2021, can I utilize the spare in the new vehicle?
They both have 19" rims
Here, I'll teach you.
First, you gotta figure out your Lug nut pattern. Which is 114x5. Then Figure out the hub size. which is 64.1mm.
Then you gotta figure out the new car's lug nut pattern. Which is 114x5. Then figure out the hub size, which is 64.1mm.
the two cars have exactly the same wheel specs. Yes, you can use the spare.
I used www.wheel-size.com to find the specs
Styl1n
The spare will probably fit, but Acura told me the spare tire kit will not. I had the spare tire kit in my 2018 TLX, but Acura parts told me the new kit is smaller to fit in the well above the battery.
2021 tlx spare tire kit
Does anyone have the instructions on installing the TLX spare tire kit? I have the parts layout but am missing some information.
Also not sure if the compressor that comes with the car with fit in the "Box Tool" which is the spacer below the cover.
Good morning; Kind of Pissed right now; I've leased 7 Acuras since '98; they always gave me the Pull ahead program, to knock 5 or 6 lease payments off, the current vehicle, if you leased the newer model. Now, that program is for all Acuras EXCEPT the 2021 TLX; what balls; they raise the price of the car $5,000, & treat their current lessors like dirt! Someone mentioned a 2021 TLX Bridge Program. I called Corporate, & AHFC; they claim it's a RANDOM offer to specific customers; what am I, dog meat?it's a $1,500 incentive for current TLX owners, to get into a 2021. Anyway, if things don't change, $47,500, is ridiculous for a 4 cylinder AWD A-SPEC. Have to look at BMW, Genesis, & Audi; HORRIBLE CUSTOMER RELATIONS
The following 2 users liked this post by CPR:
04WDPSeDaN (10-15-2020),
OtownPSU (10-15-2020)
Styl1n
https://acurazine.com/forums/second-...-fully-990477/
The following 2 users liked this post by kuzdu:
iWhine S/C 6MT TL
I'm sorry you had to go through this. It's the unfortunate fact for Acura buyers now. Check out other brands and see what works best for you. Best of luck my friend!
If you can wait, I'd wait. Since I checked on Monday, the 5 dealers in my area have all increased their inventory of '21 TLXs. I'm assuming they're not moving terribly well. Maybe in the dead of winter when all car sales take a nosedive, you'll be able to get the lease offer you want. But, don't be apprehensive to shopping around either. From the lease offers I've seen so far, you could probably get into a higher tier German variant as opposed to the TLX. I'm seeing people lease M340i xDrives for $550-599/mo ... and that vehicle will literally embarrass a 2G TLX. With leasing, reliability won't be an issue. Even still, Toyota was fond enough of the B58 to put their reputation on the line with it in their Supra, so it's probably well put together. Best of luck.
Saw the car on Sunday; there is a fitted space, under the battery cover, that fits the spare perfectly!
I've decided on either White/Red/SH-AWD/ASPEC, or Grey Metallic/Red/SH-AWD/ASPEC
Whichever becomes available 1st, I'm all in
Dealer made me an "offer I can't refuse"
I'm dealing with the owner/GM, who made the lease easy to accept
When I close the deal, I'll reveal the stats; trust me, I'm ECSTATIC!
a35tl (11-04-2020)
New ASPEC
Hey guys; pulled the trigger on this Steel/Red ASPEC beauty; picking up next week; this pic. is before detailing, & prep; post REAL pics. after!
Steely Carl
Steely Carl
The inconvenient truth
Why is it when I google 2021 tlx bolt pattern I get 5x120?
Does anyone know for sure if its 114 or 120?...
6G TLX-S
Is the 2021 TLX bolt pattern not 5x120 ?
6G TLX-S
6G TLX-S
Justnspace used www.wheel-size.com to find the specs, which is 5x114.3. However, you use www.wheel-size.com and find instead 5x120.
Therefore, the info there may not be correct, and so not to be trusted.
It is best to go and find the factory release OEM specs, or go to a dealership, or ask a new TLX owner to help measure the actual bolt pattern size.
SPARE TIRE UPDATE:
Forget it; tried putting my brand new Donut, from my 2018, 19" TLX, into my Brand New 2021 TLX ASPEC
It will NOT fit in the trunk, over THE BATTERY
Service Mgr, tried everything; no use; sold the spare for $10 to one of the Service techs; lol
As I've stated before, tire insurance, is a must, included in any lease deal in NYC!
Only real potential problem is a blow-out, or sidewall tears
At that point, a tow is your only option
Anyway, LOVE my new TLX/ASPEC SHAWD!
If it makes you feel better there is a fair chance that it would not have worked anyways. Unless the dealer has definitively told you that the 2021 tlx is also 5x114.3.
6G TLX-S
Thanks to EE4Life. EE4Life has provided the factory instructions for the installation of 2021 Acura TLX 19 Inch Aluminum Wheel.
The wheel spec is 5x120.
http://www.urvi.net/forumfiles/SB/BII14301-31.PDF
6G TLX-S
Also, Acura has pulled the "Spare tire option" from the 2021 TLX accessory order list.
So it is highly likely that the car cannot carry a spare tire at all.
Also CPR should fire the service manager who tried to put a 1g tlx donut into a 2g tlx trunk. Imagine it fit then you get a flat and have to use it only to find out it doesn't work due to having a different bolt pattern.
ELIN (12-03-2020)
jprivco
4G TL Problems & Fixes
02-12-2022 01:30 PM
Tony Pac
4G MDX (2022+)
177
07-22-2021 05:02 PM
