Can you rearrange the radio presets?
Old 11-04-2021, 10:11 PM
smith12895's Avatar
Just got my 2021 TLX and I programed the preset stations on the infotainment system. So, I had are 4 pages with 4 presets on each page and then I removed one of the presets on the first page and now there are 3 presents and an empty space on the FIRST page. I have tried in vain to figure out how to add present station to fill that space but, as far as I can tell, I can only add a station to the last page. Is there a way to rearrange the presets or to insert a station? Do I have to delete all the presets back to the empty space and start over? If so whoever the UI/UX developer was should be fired...
Old 11-05-2021, 11:31 AM
DLM1213's Avatar
Yes.....I would like to know the answer to this one also.
Old 11-05-2021, 05:24 PM
fjpthree's Avatar
I fooled around with the presets and could not figure out how to add a station to the empty space. Just deleted all the stations to the right of the empty space and then added from there. It only takes a few seconds to delete and then add.
Old 04-29-2022, 02:59 PM
lacough's Avatar
I guess there is still no resolution to this? I noticed this the other day when setting up my new type S
Old 05-19-2022, 01:51 PM
rwg105's Avatar
Yes, you can definitely move/rearrange the presets. Just hold the pad down for a few seconds on the preset you want to move. At this point you will be in edit mode and the preset will be outlined. Simply scroll to the spot you want to move it to and select it with the pad. All the other presets will move over one to the right.
I do remember when setting up my presets it got finnicky where there was a blank preset that I couldn't move anything to that location. If I remember correctly, I ended up deleting the blank preset, added the preset I wanted at the end, and moved it to the position I wanted it to. Hope this helps.
rush^^
11-30-2008 08:54 AM
RJANACONDA
12-18-2006 10:20 AM
stanwelks
12-15-2006 01:24 PM
frebay
12-01-2003 10:39 AM
Quick Reply: Can you rearrange the radio presets?
