Mirror Puddle Light Replacement Question
Hello all!…I just bought a 21’ TLX A-Spec SH-AWD….love the car, cuddos to Acura! The puddle lights on the mirrors worked the night I bought the car, and then the second night, after washing the car…the drivers side quit working and the passenger side is very dim. I’ve done some searching on here and apparently it’s a know problem on even older TLX’s. However, no one has posted actually how to replace the lights??
My question is, does anyone know if the entire mirror housing needs to come off the door to switch it out? The dealer said they’d replaced them but I’m not a fan of having my new car taken that much apart over a light.
I’m hoping the actual mirror glass comes off to access the bulb?
Or possibly, I’ve looked underneath and noticed that a cover piece might come off, but hard to tell….
Any instructions or tear down pictures/diagrams would be much appreciated!
Thanks!
Matt in Oregon
Thanks!
Matt in Oregon
The omly issue I ever had with my 2018 TLX ASpec was the puddle lights, and I just had the ones on my 2021 TLX Aspec replaced when purchased, as they had the car for a while. I can't tell you the exact steps but they require sat least an hour or so to replace the bulbs. According to my Service guy, he believes its a design flaw, at least on the previous gen, due to moisture getting into the housing in which the bulb sits, likely shorting the bulb. For my 2018, they surrounded the housing with some grease to prevent that. I suspect the same issue applies to the 2021. I no longer spray the mirror face directly while washing my car, to see if I can prevent this nusance. IHowever, the replacement is always done free of charge and I enjoy driving the various vehicles I get when bringing my car in to my dealer that's only 15 min away. However, I can see it might be a pain in the neck for others.
Designing puddle lights is not rocket science, don't understand how they could screw that up. FWIW Three says ago replaced the factory base lights with logo versions. About a minute and a half per light.
Puddle lights for many cars brands, from plain white to various logo, run from $5 to $29 a set for 2 or 4 door cars. Amazon sells them.
No its not a TLX or TL. The "For What Its Worth FWIW" was referring to a different make that has an easy to change design. But to answer how I did it - there is a notch in one end of the light. You pry it up the end a little with a small flat blade screwdriver then use your fingers to gently work it out. The entire unit comes out. A keyed plug, so you cant screw up the electric polarity, slides out of the light, then its reverse the process to install.
Thanks for the reply, yeah I know it’s free of charge and all…but my dealer is 3 hours away and like I said, I don’t want my whole door panel taken apart over this. I talked with my service advisor and he even got a tech on the phone and said it was “hard to tell based on the instructions from Acura” if the had to take the mirror off LOL….. but they were going to take a look at a new one on their lot and get back to me… So if this is a know issue on a brand new car, I’m sure at some point down the road we will all be replacing these ourselves out of warranty. If anyone who’s done this wants to give a step by step, that would be great.
Well, I have the same issue. The light at the bottom of the side view mirror on the driver's side mirror isn't working, but the passenger side is working. Just picked up the car Saturday.
Service info here: https://unknowntransportation.com:8443/Service/TLX/
"Outside Mirror Area" has sort of an exploded diagram and some pinouts. Using the electronic wiring diagram the 28 pin connector in the panel is here:
15 TAN ILL-(LED) 16 GRY ILLUMI+
But holy hell what a wildly complex amount of wiring needed for a mirror. The LED is replaceable it looks like but again it basically involves disassembling the mirror.
Update
Thank you for the link, however none of them load for me??
Well my service guy finally got back to be about my question in this post. He said that the tech said, that the door panel didn’t need to be taken off….that the mirror comes apart. When I asked the service guy how does it come apart, he said he didn’t know.
Ive watched several videos on YouTube, none of a TLX, but cars with puddle lights. They all require you to pop off the mirror glass. And the mirror isn’t double sticked, it has clips and what not. So at this point the dealer can deal with it.
ALSO…the dealer ordered the parts a month ago and the ARE ON BACKORDER…haven’t heard back.
I wouldn’t be a bit surprised if Acura knowingly put faulty lights in our cars to get them OTD. Seems suspect.
I've only done it on my '12 Accord but basically the mirror glass hooks on and has some double sided sticky tape on it that keeps it "locked in". To pry it off you basically have to lift from the bottom, wait for the double side adhesive to let go based on the pressure, and then it swings up releasing from the hooks. From there you have access to various screws and clips and crap that assemble the mirror. I made a how to with pictures: long ago here: https://www.driveaccord.net/threads/...r-glass.75788/. I would assume that a '21 Acura is the same procedure just with more crap in the mirror housing like motors and lights and connectors (and reading the service docs it seems like this is the case). I suggested the door panel route because it's straightforward to pop off the door panel for electrical troubleshooting and non-destructive like taking the glass out is.
But yeah, let the dealer fix it.
Thank you all for your responses…the lights have been on back order still….going on 6 weeks. It seems that there are quite a bit of us with puddle lights that don’t work since new. Has anyone seen an Acura TSB on this yet? It seems too common not to be a know problem.
I got good news yesterday...my Acura dealership ordered parts for my driver's side lights-they already came in and I have an appointment for it to be fixed Friday afternoon....I'll keep you posted.
Nice, I believe it has to be a defect in the wiring on some of the side view mirrors. I'm sure if it was just a bulb they would replace the bulb at a much lower price vs a whole assembly
Ask if it's a permanent fix or it'll go out again next time you wash your car/it rains.
I have the same issue on my 21' Type-S after I washed the car. @Steven Bell since yours is replaced, have you tried washing the car and testing that it still works?
Not yet....I guess I should give it a try!
Thanks!
Matt in Oregon
Thanks!
Matt in Oregon
We had heavy rain yesterday and I was driving through it. Tonight my driver side puddle light was flickering and then it just stopped working completely.
2021 Type S built in August.
Guess I will let the dealer know it’s happening to me now. But I’m sure it’ll happen again.
On the plus side, the puddle lights seem to be the only common problem being reported. That's remarkably good for the early cars in a new generation. The early vehicles in the 3rd gen Honda Pilots had a number of issues, especially the first year (2016) ones.
Right. I'll take a faulty puddle light over a jerky transmission like the 1G rollout had!
Guess I spoke too soon. There are a number of people who have had a noise problem with their steering racks.
