Maintenance Minder Did Not Reset After Service
So I got service done at Acura dealer. It was the A6 service. According to them they did an oil change, brake fluid change and differential fluid change. But after getting my car back the maintenance minder did not change. Usually it would say 100 percent but it still says the percentage it said before I got the maintenance done.
Is that something the dealer is supposed to reset? Perhaps they forgot? Or is it something that is supposed to automatically reset back to 100 percent?
The dealer should do this on every service where it's requirement, they just forgot.
This may be something you can reset yourself; your manual may have a section where that is detailed.
Otherwise, the dealer should be able to do it, just drive in, an appointment should not be necessary, the service/greeter person can do it on the spot.
Good luck.
Good luck.
digilla
1/2G MDX (2001-2013)
10-19-2019 11:59 PM
