Car wash
Old Aug 12, 2025 | 06:54 PM
new's Avatar
new
Car wash
Whenever I run my 22 tlx type s through the wash, it bends my exterior door mirrors out.
Should I worry?
I do retract them prior to wash.
Old Aug 13, 2025 | 08:46 AM
Obolonsky's Avatar
Touch less?
Is it a touch less car wash? What is the psi?!?!
Old Aug 13, 2025 | 07:34 PM
GhostTL09's Avatar
If you go through an automated, and you have the Aspec side skirts they will get scuffed up beyond repair. You've been informed.
Old Aug 14, 2025 | 06:23 AM
new's Avatar
new
it’s not touch less.
the brushes bend the mirrors sometimes
Old Aug 14, 2025 | 08:17 AM
bilirubin's Avatar
A touchless wash is safer, and if you can, avoid the scratch-and-shine (the contact automatic washes with the spinning brushes), especially the ones with the metal rails.
Old Aug 14, 2025 | 10:00 AM
jhb31's Avatar
Out in my parts there are virtually no touchless washes beside the self service with the wand which you may as well just get a foam cannon along with a cheap electric power washer. Even that is only good if the car is barely dirty. I resigned to hand washing. My prior blue TLX Aspec I took through the car wash a few times and it ended up will a zillion micro scratches from the roller brush (very visible in certain light). We do take our new SUV through the car wash as it's just too big for me to want to wash/dry by hand.
Old Aug 15, 2025 | 11:55 AM
visi_d's Avatar
I did a video on my tlx recently and i mentioned the same thing lol...No automated car washes if you have the optional side skirts. You will regret it. Doesnt take long to start seeing the results either
Old Aug 20, 2025 | 07:01 AM
MarcoTLX's Avatar
Adept Acura Enthusiast
To add my 2 cents to this, I only ever take my Type-S to self-service car wash bay where I can use the spray to wash and rinse my car. Or I go through a touchless carwash but I have NEVER let any brush of sorts at any carwash touch my car lol
I use touchless car washes that look pretty much like the above picture, safe and it is truly touchless without needing to hook up onto some rail to ride down a tunnel.
I would presume the above pictured touchless wash setup would be safe to go through with A-Spec sideskirts?
Old Aug 21, 2025 | 08:23 PM
GhostTL09's Avatar
Yes, because that water pressure only to clean. Those spindles put gashes in the plastic 😳. Don't do it.
Old Aug 28, 2025 | 01:20 PM
walmark's Avatar
Keep in mind that touchless car washes use much harsher chemicals to clean the car, which strip out wax and any coatings you might have put on the car. They will also damage clear coat over time if the car is not regularly waxed. "Soft brush" car washes typically use milder detergents. It's a trade-off.
Old Aug 29, 2025 | 07:54 AM
user 429785240895240's Avatar
Exactly why I only hand wash and have never been through a car wash on any kind. I'd rather drive a dirty car then risk scratches or worse.
Old Aug 29, 2025 | 08:05 AM
MarcoTLX's Avatar
Well that sucks I only use touchless wash twice a month really as I don't drive my TLX much though I am driving more recently before the summer wraps up and it starts getting colder.
Old Aug 29, 2025 | 08:13 AM
bilirubin's Avatar
I wouldn't say a touchless wash will strip "any" coating. Ceramic coatings withstand pH levels of 2 to 13 and last several years (typically 2 to 10 years depending on the product). Ceramic spray-and-wipe sealants can typically withstand 10 or more strip washes and still remain on the surface at least 3 months (some up to a year). You're right about waxes though.
Old Aug 29, 2025 | 09:40 AM
walmark's Avatar
Correct. I meant any coatings that you would typically put on after wash, such as wax, quick detailer, plastic shine, rainx, etc. I didn't mean semi-permanent coatings like ceramic. Although even ceramic will still get damaged over time if not protected by wax or ceramic sealant, which again get easily stripped and need to be reapplied more frequently when using touchless washes.
exceldetail
Wash & Wax
Jan 12, 2009 08:59 AM
Shalooby
Wash & Wax
Oct 16, 2006 03:15 PM
G
Wash & Wax
May 13, 2005 08:16 PM
dailo
Wash & Wax
Jun 27, 2004 11:27 AM
Y2K_TL
Jan 9, 2003 11:13 PM
