Aftermarket front lip/splitter on A-Spec
from artworks body shop ...i like the look better then the oem splitter ....it follows the lines of the bumper better then the factory one
The following 2 users liked this post by djjoe:
KrylonBlue (02-26-2022),
silverTL6 (02-28-2022)
Received 6,470 Likes
^^^ No, you don't...I didn't remove the entire front bumper to install mine.
https://acurazine.com/forums/second-...nd-era-994810/
correct ..you don't need to remove the bumper at all, you don't even need to remove all to bolts the instructions say to ...they did send some wrong size hardware which we had so it wasn't a problem , but if we didn't i wouldn't have benn able to instal
the screws that fasten the lip...just the ones on the very side next to the tire / under the two front spoilers form the add on body kit..they were to short to use the provided spacers, you would need a little longer ......and ....im not sure what its called spring nut?....the square nut that you slip onto the plastic...they were to small also
JayR1021
07-23-2012 08:48 PM
JRock
04-26-2004 02:00 PM
