Wider Tires on TLX
Old Jan 24, 2022 | 11:47 AM
DT9411's Avatar
Wider Tires on TLX
Hello, after we had a tree fall on our garage last year, my pristine 2012 Tl Sh-awd BWP 6mt was sadly totalled, I bought a 2015 TLX sh-awd elite last year, really appreciating the better gas mileage and quieter ride. Missing the 6mt! May need to do a rear sway bar and J-pipe to get this car where I want. Anyways, I've got a set of TSW Bathurst rims sitting in the garage, just curious if they'll fit the car and not rub or anything? The rims are 19x9 with a +30 offset. I have 255/40R19 tires as well on them. Right now I'm on winter tires, (northern Ontario, pretty much a requirement). The stock goodyears are in a word, crap. Once spring rolls around, I'd like to put these rims on the car. Summary, 2015 tlx awd, 19x9 +30 with 255/40R19, square setup, will it work? Any thoughts and opinions appreciated!
Thanks, Dan
Old Jan 24, 2022 | 07:29 PM
csmeance's Avatar
Are the wheels off your 2012 TL? They may not fit as TLX has 5x114.3mm bolt pattern, where the 4G TL 2009-2014 has 5x120mm.
Old Jan 24, 2022 | 08:10 PM
DT9411's Avatar
The wheels are off my 1g RDX, which has the same bolt pattern as the TLX I believe, pattern is 5x114.3. Should have clarified that. More so worried about clearance and if it'll rub anywhere. Don't plan on lowering the car much or at all due to winter weather. Thanks
Old Jan 25, 2022 | 01:18 AM
fiatlux's Avatar
Should be fine, the factory 19" tires are 245/40R19. I don't imagine 255 would be a problem.
Old Jan 26, 2022 | 11:45 AM
DT9411's Avatar
Awesome thanks, hoping they fit with no issues! Was worried that the higher offset and wider rims and tires may rub on the fender possibly. Good to know that it should be fine.
Dan13
Oct 10, 2018 09:51 AM
TMQ
24
Apr 1, 2011 08:14 PM
vfrooom
Sep 5, 2008 10:51 AM
TL-Rocket
Apr 3, 2005 05:10 PM
nym31mp
Nov 17, 2003 08:53 AM
