Thoughts on wheel and tire setup
Im looking to purchase wheels with correct fitment. I'm fine with rolling my fenders but nothing more.
19x9.5 +25 in the front 225/35/ZR19, 19x10.5 +25 in the rear. 235/35/ZR19
will be lowering the car with coilovers. I've done extensive search to even get a clue on the fitment of something like this, fitment calculators dont really give me what im looking for and I can't really compare it to other vehicles. ( My Sc300 fit 18x11 rears no problem with a good roll no rubbing )
I've only seen either bagged setups which are exaggerated fitments with crazy setups (19x11 -10 type setups) or very subtle setups with a small drop and wheels with less than a 9 width
This is my first new sedan vehicle and im trying to do it right the first time. any suggestions or inputs?
Wheels im trying to fit for those curious.
it's funny when you say you want to roll fenders but nothing more...
what if you need to cut fender tab?
it's not what you need, rather what your wheels need to fit...if they need other things then fender rolling...you'll have to do it
and with the the coilover route, you have the option of ride height...so...get the wheels on.. adjust height....adjust fenders...play with tire size...play with camber..
wheels are not one size fits all, rather it will be a guessing game and you will be putting in work to get them to fit correctly
was hoping for someone with similar wheel size and offset to chime in
i'll try it out when its not 10 degrees in NYC and post results
