Offset question
Offset question
I have a of spare set of rims from the 07 altima 3.5 SE. It's basically the size of our stock 17s, but offset is +45, instead of +50 (see below).. Any idea if this would cause issues? I'm planning on adding the tpms on them and use as winter setup.
TLX
wheel size - 17*7.5
bolt pattern - 5x114.3
center bore - 64.1mm
offset - +50mm s
tock tire size - 225/55R17
Altima 3.5SE
wheel size - 17*7.5
offset - +45mm
stock tire size - 225/55R17
Page 1 of 1
TLX
wheel size - 17*7.5
offset - +50mm s
Altima 3.5SE
wheel size - 17*7.5
offset - +45mm
Page 1 of 1
Received 7,772 Likes
If that is all correct, it will stick out 5mm more.
If you're stock height, it shouldn't be a problem.
justnspace (12-29-2015)
I also believe the Altima's hub bore size is 66.1, not 64.1 , which means OP may want to pick up a set of hubcentric rings.
Mr24v
08-14-2016 10:19 PM
mlody
18
01-20-2016 11:07 AM
