mild vibration at red light (in gear)
Old Nov 25, 2014 | 11:04 PM
clk350's Avatar
I did noticed when I test drove couple of I4 TLX (including mine), there was mild constant/noticable vibration. it didn't bother me so much that time.
Today, I was stuck in a traffic and I got annoyed by it. i felt tired by it.
It is only noticeable while sitting at idle at a traffic light. when I put the gear in N, it's a bit better.
It is a mild but I can feel it in the steering wheel and in the seat.
Even my wife's 08 MDX with 100K mile doesn't vibrate like this.
Is it common for the TLX?
Old Nov 26, 2014 | 09:30 AM
tlxsteve's Avatar
I haven't felt or heard this vibration in my TLX and I have stopped at a lot of red street lights. Just passed 4,000 miles recently.
Old Nov 26, 2014 | 09:44 AM
Most, if not all Acura's use vacuum assisted engine mounts.
maybe a change in load can affect how much NVH can enter in the cabin
Old Nov 26, 2014 | 10:17 AM
clk350's Avatar
I had mixed feeling for this i guess.
I wished it's a common problem. at the same time that means I have to live with it...which will be challenging for me...
Still I am glad Steve doesn't have any vibration.
I searched the web and CRV has similar vibration issues but with different reason (low RPM) than mine (my TLX RPM at idle in gear is around 800 to 900).
Well I guess I have to take it in to dealer once the body shop finishes their corrective work... Damn.. tired of all these fiasco...
Old Nov 26, 2014 | 10:20 AM
clk350's Avatar
Vibration is pretty constant all the time in different settings though.. (day, night, rain,
ac on, off..etc.)
Old Nov 26, 2014 | 10:27 AM
ac on, off..etc.)
it could literally be anything, then.
almost all moving parts will resonate.
Old Nov 26, 2014 | 10:30 AM
clk350's Avatar
Sorry... what I meant was that when I am at a red light in gear...
while moving, it's fine.
Old Nov 26, 2014 | 11:46 AM
tlxsteve's Avatar
Maybe have a good friend stay in the trunk when you stop at a light to see if your friend can locate the vibration?
Old Nov 26, 2014 | 03:49 PM
clk350's Avatar
Haha... Well... When I mentioned "someone getting into trunk of my new car"... most of my friends worried about blood stains on my new trunk liner.... Hmmm...
Old Nov 26, 2014 | 06:28 PM
Dutchy's Avatar
Maybe they didn't perform the idle learn procedure at PDI. You can do this yourself, it worked for me. I will post how its done. so easy.
Perform the Idle Learn Procedure
To ensure a steady engine idle, perform the idle-learn procedure after installing the No. 29 (10A) fuse. During PDI inspection.
NOTE: The PCM does idle speed adjustment; there is no adjustment screw. Idle-learn must be done
whenever you reset, update, or replace the PCM, or replace or clean the throttle body. It does not need
to be done after you erase DTCs with the HDS software on ETecH, or after the battery has been disconnected.
1. Make sure all electrical items (A/C, audio unit, defogger, lights, etc.) are off.
2. Start the engine with the shift lever in P, parking brake on, and hold the engine speed at 3,000 rpm until the radiator
fan comes on.
3. Let the engine idle for 10 minutes with the throttle fully closed.
You can turn the car off after 10 minutes. That's it! This is for ALL Honda/Acura's.
Old Nov 26, 2014 | 09:44 PM
tlxsteve's Avatar
Very Interesting. Thanks. I will pass this onto my friends with vibration/idle issues.
Old Nov 26, 2014 | 10:20 PM
clk350's Avatar
fan comes on.
Dutchy..
Thanks. I will definitely try that tomorrow morning!!
Dutchy's Avatar
No problem.
Old Nov 26, 2014 | 10:21 PM
Dutchy's Avatar
Dutchy..
Your welcome.
Old Jan 5, 2015 | 09:20 AM
NRS78's Avatar
The 4cy does have a bit more vibration than the 6cy. I noticed this in my TLX compared to our Pilot. One question though, have you noticed that the brake pedal is very hard to push down when you start it after it has been sitting for a few hours or overnight? My TLX had more vibration than my TSX had, and I am having this brake pedal issue. The dealership thinks it is a vacumm booster, and it is in the shop for this right now. A vacumm leak would certainly cause the engine to be a bit rougher on idle. Just curious if you are having similar symptoms.
Old Jan 5, 2015 | 10:38 AM
Quandry's Avatar
It seems that the vacuum pressure for the brake is not contained to the same extent as previous Acura's. The hard brake pedal feeling when the car has been out in the cold for hours has been reported previously and I do not believe that it is a fault, but it will be interesting to see what the shop reports. You can easily simulate the condition by pressing the pedal a couple of times with the engine off.
Old Jan 5, 2015 | 10:55 AM
NRS78's Avatar
I'm interested to see what the shop reports as well. The brake system should however be able to hold vacuum for several days. The loaner TLX I have been using for the past couple of weeks has never once had this problem. It even sat for a couple of days with an ambient temp in the 30s, and when I pressed the brake pedal to start it, went down easily. The idle, and even lower RPM (1200-1300) driving- when it upshifts into higher gears driving through town, is definitely rougher with more vibration on my car than with the loaner TLX I have been driving. I'm hoping the new vacuum booster resolves both issues.
Old Jan 5, 2015 | 11:09 AM
CheeseyPoofs McNut's Avatar
Mine does the same thing regarding the brake pedal. It started when the weather turned cooler however it doesn't happen every morning. I'll be interested in hearing what the outcome is for you - at this point it's just another thing for me to mention when I take the car in for the first oil change in a few months. My list is getting longer and longer
Old Jan 5, 2015 | 06:15 PM
t33h00's Avatar
I felt that when I dropped my TLX V6 for service and got the i4 TLX for loaner car.
Old Jan 5, 2015 | 09:23 PM
clk350's Avatar
I have not noticed the brake pedal issue yet since I didn't even know that's not normal...^^
I will try tonight.. very interested to find out...thanks!
Old Jan 6, 2015 | 12:34 PM
Colin's Avatar
This. A 4 cylinder is inherently uneven and even though there are balancing shafts, there is still more vibration than a V6 or straight 6.
Old Jan 6, 2015 | 12:44 PM
clk350's Avatar
I agree... since the TLX is my first I4, that's the reason I noticed the vibration more. trying hard to get used to it but...not so easy...
Old Jan 6, 2015 | 03:25 PM
hadokenuh's Avatar
Yep, it's an I4. You will eventually get it at some point. Hell, I experience the vibration from time to time in my newer V6 Acuras. In this regards, I think only Lexus can give you a total smooth and vibration free experience. I've owned some older Lexuses, they were smooth even at 100K miles.
Old Jan 6, 2015 | 06:20 PM
clk350's Avatar
Well.. My CLK was very smooth.... Sometimes I had to check if the engine was running... Seriously!...
However, days like today with slippery snow... I am glad I was driving TLX though.
Old Jan 9, 2015 | 12:13 PM
NRS78's Avatar
I finally got my car back from the dealership after 17 days (was asked to test the loaner for a while, then holidays happened, then waiting for parts)... They replaced the vacuum booster on my car. This morning the brake pedal depressed normally when I started it. They agreed with me that it was not a normal thing to have the brake pedal be so hard to depress after just a few hours, so for anyone experiencing this issue it may be a vacuum leak.
As far as the vibration, it seems a little better than before. Hard to tell if it is just me thinking it is better or not. The 4cyl does have a bit more vibration anyways, but it does seem like it is better than before. Unfortunately, the transmission still feels the same, but I didn't really expect any change to happen there.
rockyboy
Aug 4, 2024 10:35 AM
redsox68
Sep 16, 2015 06:18 PM
PortlandRL
Sep 14, 2015 12:01 PM
thisisnotdave
4G TL Problems & Fixes
Sep 8, 2015 10:02 AM
Papa Roe
Sep 1, 2015 09:41 PM
