Does the TSB 15-038 help or hurt
Old Nov 5, 2015 | 06:03 AM
Jayellin's Avatar
Had the TSB 15-034 done to prevent my TLX SH AWD shifting into neutral. It also improved throttle response and eliminated harder shifts but deactivated the Auto idle stop. I like the way it drives and don't use the auto stop anyway. Service department says TSB 15 -038 will fix auto stop. Will it affect anything else Anyone had this done ?
Old Nov 5, 2015 | 12:38 PM
sbillard's Avatar
The "deactivated Auto Idle Stop" is an indication that the update was not applied correctly. Happened to me as well, but I took the car back the next day. They re-did the process and everything is working fine now. Doing TSB 15-038 "correctly" will fix things, but would not have been needed of 034 had been done correctly in the first place. Both TSBs effect the same subsystems.
Others have reported that Auto Idle Stop will eventually come back "magically".
Old Nov 5, 2015 | 01:24 PM
mapleloaf's Avatar
Any change in throttle response when applying full throttle to pass and downshifting multiple gears, especially rom slower speeds?
Old Nov 5, 2015 | 03:15 PM
Jayellin's Avatar
Slight delay but then it downshifts and takes off. Much improved throttle response overall
Old Nov 5, 2015 | 03:53 PM
Jayellin's Avatar
Well I guess my dealer doesn't think anything was done I correctly so I don't know if I want anything am else done right now as the car is fine except for the Idle stop.
Old Nov 6, 2015 | 06:22 AM
Jayellin's Avatar
And like magic this morning without doing any further updates the auto idle stop is now working. I hope the other improvement in the car remain. Time will tell
Mr. ShawnJ007
May 18, 2016 09:42 AM
RDX10
1G RDX (2007-2012)
39
Nov 25, 2015 09:13 AM
MrCleanTX
Nov 24, 2015 10:30 AM
Jayellin
Nov 12, 2015 08:08 PM
Nitin
Mid-Atlantic
Nov 6, 2015 03:21 PM
