Climate Control Not Turning On
Ok, so my car had 5 or 6 aftermarket accessories that I wired into the fuse box and they were draining my battery. I recently went in to pull them all out and when I was done, my power mirrors, seat heaters and climate control were dead. The radio works, but the climate control won't turn on. Some of the fuses still had wire wrapped around the prongs when i was done. Would this have killed each fuse i did this too? Some of the prongs look burnt, but the middle of the fuses are in tact. Could it have screwed up anything else in the car with my shitty mechanicry? Which fuses should I replace? Any help would be greatly appreciated... I'm just worried that a dishonest mechanic is gonna tell me I need a whole new unit and charge me $500 to replace a 20 cent fuse and I'm pretty close to being broke.
If the fuse prongs look burnt, replacing a fuse normally won't solve the problem, but could easily aggrevate the problem. Suggest you find yourself a good electrical mechanic and be very honest of what mods you made and then removed. This will help him diagnose the problem and resolve it as quick as possible.
Billu99tl
1G TL (1996-1998)
Jul 15, 2018 09:37 PM
MrX123
Oct 3, 2010 04:07 PM
cd5-obsession
Jul 12, 2008 10:54 PM
MikeTL-S
Dec 6, 2003 11:38 PM
