Battery issue
Old Dec 9, 2020 | 02:23 PM
noclue02's Avatar
Battery issue
Hi all, I noticed my battery's negative terminal has corrosion all over. From what I know, the battery is under charge. I plugged in my 1a/12v charger, and left it on for good 4-5 hours. Few days later I noticed my battery cap has some fluid leaking out. I google this and found out it overcharged? How do I correct this issue with my terminal corrosion and acid leaking?
Old Dec 9, 2020 | 07:53 PM
csmeance's Avatar
Is your charger a smart charger? The TLX uses AGM battery and it can be damaged by using the wrong type of charger.
Old Dec 10, 2020 | 12:38 AM
noclue02's Avatar
Mine is a 4cyl so I got the regular battery, not AGM . I bought the Noco Genius 1, something small and compact. I believe it switch to trickle charging once battery is full.
Old Dec 10, 2020 | 01:20 PM
csmeance's Avatar
clean the terminals off with solution of baking soda and clean off excess acid carefully and see if it is leaking. When the battery charges, sometimes the acid can boil inside and create pressure so it leaks out.
Old Dec 11, 2020 | 11:01 AM
noclue02's Avatar
Thanks csmeance. The leak makes sense so I'll wont leave the charger on for too long or too often. As far as the terminal, I did cleaned the terminal but it came back again. I do have a capacitor for my amp. Wonder if that thing is draining the battery overnight....
AZuser
Money & Investing
25
Feb 15, 2022 04:56 PM
crazyvlad
ILX Problems & Fixes
Jun 8, 2020 10:15 AM
tsxhighwire
1G TSX Problems & Fixes
Aug 26, 2013 04:52 PM
mcnally215
Sep 28, 2009 11:40 PM
gldman
Feb 23, 2004 10:11 PM
