View Poll Results: Smartphone Mirroring For TLX?
Interested
![](https://acurazine.com/forums/images/maestro/polls/bar2-l.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar2.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar2-r.gif)
![](https://acurazine.com/forums/clear.gif)
26
92.86%
Not Interested
![](https://acurazine.com/forums/images/maestro/polls/bar3-l.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar3.gif)
![](https://acurazine.com/forums/images/maestro/polls/bar3-r.gif)
7.14%
Voters: 28. You may not vote on this poll
NavTool Video Interfaces For TLX
Hi guys, we want to thank each and every one of you for products support and thank you for buying our products.
We are here to help with all the questions, we also have special pricing for forum members.
We are staring Pre-order for Acura TLX
NavToolDVI-HDMI features:
1. HDMI input: you get true HD mirroring form any smartphone without restrictions, absolutely everything you have on your smartphone will be mirrored to your vehicle screen.
2. Audio output: connected HDMI source will play audio via 3.5 mm audio jack on NavTool. it's possible to run audio from NavTool 3.5 mm audio jack to vehicles AUX 3.5 mm audio jack. It's is also possible on some smartphone to stream audio via vehicles Bluetooth streaming option.
3. USB charging: keep your smartphone charged at all times or provides power for android MHL adapters.
4. 4 composite video inputs
connect front camera, and side cameras
front camera will operate out of reverse below 10 mph per hour
side cameras used as lane watch cameras and will activate with turn signals above 15mph
5. USB update - if such updates are necessary in the future.
NavTool is controlled via navigation Cancel button and inputs are selected via navigation Rotating JOG.
Use smartphone for navigation on non nav vehicles.
use apps like Waze or Any smartphone app navigation instead of factory Nav.
We will launch a group buy in sponsored section, if you have pricing inquires please email or PM me.
Post all your other question here.
Thank You.
Thank You.
When will you be accepting the pre-orders and approximately when will the devices be available (if known).
I've been checking for this item on your website for a few months now and I'm very excited that it may be ready soon.
Thanks for posting this.
Thank You.
Thank You.
Anything like this coming for RLX? I would certainly buy this to have the options you describe. I'd LOVE to be able to add a front camera on my 2014 RLX.
The connections can't be that different from the TLX?
RLX and TLX will use the same interfaces they both have identical headunits.
Thank You
neuronbob (10-04-2015)
Just so you know Naviks already had an RLX interface a while now. Oddly enough while I agree with Navtool to assume it has the same interface as the TLX they're not cashing it in with the TLX (or MDX). Reason not explained. I inquired directly and they claim that they don't have a TLX to test.
2014 Acura RLX NAVIKS Video Interface Added: Kivic One + iPhone 6 Plus - YouTube
Naviks product picture quality is horrible, text in unreadable, you may ask why?
1. you are connecting to a device with reverse engineered Apple Airplay,now that signal is down scaled to composite video, a technology that was created in 1960, after that it connected to their generic box with a mailing label sticker on top.
2. video lagging due to reversed engineer Airplay signal.
3. video and audio appear out of sync
4. not an automotive grade
5. you have limitations, many apps like Netflix, iOS download video, YouTube will not work.
6. they use non OEM connectors and you get video to flicker on and off.
7. HD video wires are exposed.
Major issue, exposed digital video signal line without shielding
![](https://cimg3.ibsrv.net/gimg/acurazine.com-vbulletin/884x572/capture_f07edd79c05aa28a29188024311d1de6aaa7e5b8.jpg)
NavTool Solution
1. we provide full HD image to your Acura HD screen, you never what to downscale that quality.
2. all connectors are 100% OEM
3. limitless smartphone mirroring, no restrictions all apps work
4. audio and video is in sync.
5. 100% automotive grade.
6. Made in USA
there are many product out there that might work, we provide real solution for smartphone mirroring, made in USA by real automotive engineers.
Thank You.
Thank You.
1. So can your phone communicate via Bluetooth for Nav. I have an iPhone 6 and use Nav a lot, do I need to plug the phone in to get an image on the car screen or can this signal convey via bluetooth?
2. If you want to watch a movie on your phone will it also play on the car screen?
3. Is there a youtube video of this device on a TLX or MDX so I can see the features and how they work?
I have a couple questions:
1. you connect video by wire lightning to HDMI form iphone, and that will display on factory screen, you can then conenct audio via Bluetooth to acura Bluetooth streaming.
2. yes ti will.
3. new video will be out shortly
I am interested. Is the group buy still going? How hard is it to install, how long should it take?
Is there any possibility to output audio along with the video through hdmi rather than having to use a separate audio interface?
installation is simple, 1.5-2 hours
Ah, so HDMI output from phone requires us to use the AUX audio selection to hear it from over HDMI output? Ok, if that's correct, then that works. BT has a 3 second delay on the current generation, so BT is NOT a viable audio source like one other poster asked about above. Thanks for the info.
Ok that's why I asked initially if there was any possibility to output audio AND video over JUST HDMI, because technically HDMI is video+audio, rather than having to connect TWO cables to the phone. So, in essence, the answer to my original question is NO. Thanks for clarifying.
so you are only connecting HDMI to your smartphone
This may have been addressed.. But is it still possible to play audio from another source while using the NavTool just for video purposes?
For example, using NavTool to put the GoogleMaps GPS up on the screen while still listening to XM Radio.
That's my only question, exciting stuff!!
Yes you can do that
Thank You
navtool.com
11-16-2015 08:03 PM
navtool.com
14
10-31-2015 08:16 PM
navtool.com
09-25-2015 05:15 PM
