Dual USB Charger Socket
Old Jul 26, 2017 | 08:19 PM
know610's Avatar
Cllena Dual USB Charger Socket Power Outlet 2.1A & 2.1A for Car Boat Marine Mobile (4.2A-Red)
-Package Included:1 x Red LED Dual USB Car Charger Adapter, 2 x Insulated Terminals
-Short circuit / overheat protection.
-Has two ports both charging at 2.1 amp each.
-Input : 12V,Output : 5V-4.2A
-USB outlet 5V up to 4.2A.
See Picture: Picture of dual usb just sample. The actual will say 5v 2.1A each port
Only use to charge 2 iPhone 7 whenever the rear passengers need it while on the road. I want to use with tap-a-fuse to the driver "switch" fuse.
In the fuse box, Which Amp size fuse (7.5A, 10A, 15A, and 20A), should I use for charging 2 iPhone same time while car running?
Oh, In the fuse box, What is "30A Spare Fuse" use for?
Attached Thumbnails Dual USB Charger Socket-02.jpg   Dual USB Charger Socket-03.jpg
Old Jul 29, 2017 | 04:32 PM
know610's Avatar
200+ viewers but no suggestion. It's all good. Amazon user was able to provide suggestion. I found that TLX majority fuse are "constant" power. I did a t-tap and add an inline fuse 10A. T-tap to a wire of a "center pocket" cigarette socket. Work great. That wire is a "switch".
