3 Holes and out! Help Please!!!
I drill 3 holes in the fire wall to run the amp power cable and no luck???
Can someone with aftermarket amp take a picture of where the hole is drill?
I will use the picture as a reference and I'm sure that the rest of the forum will like to know.
I'm trying under the driver side but I keep striking out.
Thanks!
Thanks!
I drill 3 holes on the DS between the steering and the pedals, I can feed the cable but doesn't come out the other side, feels like it's going inside something else. It's a lot of components on that side.
there should be a few empty grommets on the firewall for you to use. If you are creating holes, why not fish the wire though using a coat hanger or something small and rigid so you get through the whole mass?
