Throttle / slow acceleration...
Why does the TLX (mine is the 2018 FWD 3.5L V6) feel like it's not accelerating quickly relative to the sound of the engine revving?
I push on the throttle, and I hear the engine speeding up, and them somewhere later on I feel the the more rapid acceleration that I wanted. Why doesn't that feeling of acceleration come WHILE I hear the engine revving up? Why is that pushed into the back of my seat feeling coming on so slow? Exactly what is the transmission doing?
It's like Acura engineers found some way to purposefully "smooth out" (delay?) the acceleration - and yet, there is often a little jerk speeding up even if I haven't pushed the throttle in very hard.
Regarding the sprint booster, I seem to be reading some conflicting statements, or at least, those in favor if it fail to explain it properly in terms of how it is different than simply pushing the throttle down faster.
So, setting the Sprint Booster aside for a minute, could someone explain to me technically, what would be needed to not have that feeling of throttle lag? How is the transmission related? Considering the power to weight ratio of the 3.5L V6 TLX, I know it's not going to give me a "go kart" like experience, but isn't thatat least enough power to give some slight amount of thrilling acceleration? Is it partially due to the transmission not shifting up soon enough? Or almost entirely due to delayed throttle resposne. Again, I'm confused, because I hear the engine revving up faster more than what it seems it should relative to the feeling of thrust.
I don't want a "thunk" or a "jerk" from my transmission, but I do want a feeling of linear direct response from the throttle to the tires on the road.
the J-series engine has always had this quirky characteristic....it makes peak power at 6000-7000 RPM.
also where the stereotype of "loud but slow" Honda's come from.
Vtec just kicked in, YO!!!!
vtec begins somewhere in the 5k range...
if you are unfamiliar.... honda's create power by having a cam with two different profiles...a low speed profile, and a higher RPM profile, called vtec..(Variable Valve timing and lift electronic control)
Christopher. (12-11-2017)
At least there is that option. My previous Bimmer didn't and I had a $350 module installed for the sole purpose of killing that nasty throttle delay.
Styl1n
It's a good thing you didn't have a late model 2015 like most of us did, the throttle is worst. Sprint booster will fix that throttle lag and pedal travel, on my car i have the light weight pulley, sprint booster and VCM disable and my car feel like a different machine. Im sure when i get my 2018 next month it will feel even better with the mods moved to it. Everyone i spoke to didn't believe me until they drove my car.
Christopher. (12-12-2017)
From the Acura web page on IDS:
It's funny, even Acura's graphic shows that throttle response is not set to it's fastest in "Sport+":
- NORMAL – A balanced, Acura-level mix of comfort and handling. “Just right,” you could call it.
- ECONOMY – To maximize fuel efficiency, Economy mode reduces sensitivity to minor throttle input changes, allowing more consistent engine speed. Automatic climate control is also dialed back to ease load on the engine.
- SPORT – The power steering assist is reduced to increase steering feel and feedback. Response levels for P-AWS® or SH-AWD® and the Drive-by-Wire™ throttle are heightened. Active Sound Control is diminished to let in more of the beautiful engine note.
Received 2,599 Likes
In the case of a FWD the last thing you want is a high impact power engagement. FWD cars naturally loose traction on quick launches & a harsh throttle only makes it worse. RWD cars are more forgiving because they gain traction up to a point on hard launches.
Putting my money where my mouth or my keyboard is in this case any car I ran had the throttle softened including the way I have programed the COBRA which is a sub 4 second to 60 car. On the BMW's when I tracked them the JB4 system allowed me to not only soften the throttle but program reduced maximum boost in 1st & 2nd gear.
Kind of opposite of what that throttle thingy does that people buy.
timeizmoney22
1G CL Problems & Fixes
15
05-24-2012 06:50 PM
