How to reset TLX Ecu?
Hi everyone, I'm installing RV-6 hfpc and j-pipe soon on my 2016 Acura TLX. When the time comes I would like to know how to reset the ecu so the car recongnizes the added parts. Is it just as simple as unplugging the battery for a few minutes ? Or is there a specific way on how to reset the ecu? Thanks for any input!
^its the same way as your previous TL.....
unhook battery for a few mins...then connect battery....
and the ECU WILL NOT recognize the parts...ALL the parts do is just give MORE air...that's it...
so the ECU just compensates....NOTHING more nothing less...
but its the same thing as your TL....
**WhItE-aNgEl** (02-01-2017)
The RV6 HFC's shouldn't give you any check engine lights as long as they're installed properly, and the same goes with the Jpipe since that's just removing an unmonitored cat; so there shouldn't be a need to reset your ECU.
We have our XLR8 Jpipe made here inside the USA from T304 stainless steel on CNC machinery to ensure the best fit with performance in mind; so for an extra $10 you get a quality piece you cant beat!
However, we have the RV6 Jpipe along with their High Flow Cats (which I definitely recommend!) in stock too! I'll include the links below:
- XLR8 Jpipe: JPIPE-UB2-FWD - XLR8 J-Pipe - Excelerate's Honda & Acura Store - Japanese Performance Specialist
- RV6 Jpipe: RV6-JPIPE-TLX - RV6 J-Pipe - Excelerate's Honda & Acura Store - Japanese Performance Specialist
- RV6 HFCs: RV6-HFPC-TLX - RV6 High Flow Pre Cat - Excelerate's Honda & Acura Store - Japanese Performance Specialist
