Front Sensor Camera
Front Sensor Camera
Has anyone been able to hack the front sensor camera to record the images say to use as a dashcam?
I'd like to get a dash cam but they all seem so intrusive. I'd like to find something that's clean and looks as stock is possible. They all seem to need a power cord that runs up the dash.
Anyone have any ideas?
mount it above the rear view mirror, run the power wire along the top of the headliner, down the pillar trim (remove the pillar trim and place wire behind the airbag, not in front!) You can run it down past the dash right into the fuse-box. You can use an add-a-fuse and hook it up to power that is on when the car is running.
Hacking into the camera would probably be more trouble than it's worth. I have a front/rear dashcam that I've yet to install and I was too trying to determine how best to mount it. Another member just posted a DIY of a dashcam install and it looks pretty good. I'll try to attach the link to that topic here:
https://acurazine.com/forums/audio-b...nstall-933192/
It just seems like such a waste though. There is a camera already looking forward, we have a rearview camera for backing up, and there's a hard drive in the entertainment system. It seems as though it would just be a given that they would be able to have some kind of option for a clean factory dash cam in the TLX.
The problem with the current model TLX is that without knowing the specs, the front facing camera could be a crude B/W or very low def camera and don't get the owners started on the quality of the back up camera
I know that Acura and car manufacturers in general are going away from a lot of options, but it would be awesome if we could choose options like dashcams, HUD, radar detectors and other similar electronic options.
rockyboy
08-04-2024 10:35 AM
rockyboy
01-25-2016 06:00 PM
