Dash lights up with errors
Old Jun 19, 2023 | 08:52 PM
Jonboss's Avatar
7th Gear
My 2018 Acura TLX, sh-awd 3.5 litre. As of late comes up with three errors/issues all at once. It says sh-awd problem, battery charging problem, idle auto off problem. They all come up exactly at the same time. It happened before but when I restarted the car it would be gone. Now it doesn't seem to clear itself, has anyone had this issue?
Old Jun 20, 2023 | 05:47 AM
TSXV6Guy's Avatar
Suggest to start by checking the battery - many such problems are linked to the battery. If the battery is more than 3 years old, consider replacing it.
Old Aug 9, 2023 | 01:32 PM
Jonboss's Avatar
7th Gear
I did replace it, but the error still comes up. alternator seems good as well.
Old Aug 10, 2023 | 08:58 AM
Originally Posted by Jonboss;[url=tel:16900096
16900096[/url]]. alternator seems good as well.
how did you come up with the conclusion? What did you test?
Old Aug 10, 2023 | 09:11 AM
Jonboss's Avatar
7th Gear
I tested the voltage at the battery after the car was on, with some load on the battery.
And then also tested the voltage at the alternator itself. There were both at around 14.2
​​​​​​Is there more I can do test the alternator?
CYJ
Jul 1, 2022 10:08 AM
Henry93
ILX Problems & Fixes
Jun 30, 2020 08:07 PM
LVRLX
3G RLX (2013+)
Dec 13, 2019 06:47 PM
Jjj1117
Nov 25, 2017 11:10 AM
