Base and Aspec Computer difference
Old Nov 18, 2017 | 09:42 AM
kuzdu's Avatar
Styl1n
hey guys does anyone know if the ECU program is different from the base v6 and the Aspec fwd?
Old Nov 18, 2017 | 03:09 PM
BEAR-AvHistory's Avatar
V6 FWD to V6 FWD they should be the same. Aspec is trim & suspension.
Old Nov 18, 2017 | 10:36 PM
kuzdu's Avatar
Styl1n
I Think the steering ratio is the same as well and only the awd version has tighter steering modification With a better suspension.
Old Nov 19, 2017 | 01:00 PM
TacoBello's Avatar
Look up the parts number on one of the Acura oem parts sites. If part numbers are the same, there is no difference. I have a feeling this is the case, but it's always worth verifying.
Old Nov 20, 2017 | 12:24 PM
kuzdu's Avatar
Styl1n
the ECU look the same but it may have a different program for shifting. i can get a base model V6 for a good price but if i decided to get an asepc i may just make the jump to the advanced model.
Old Nov 22, 2017 | 06:24 PM
mondster's Avatar
Im guessing that the programming is different, hence the difference in mpg?
Old Nov 22, 2017 | 08:18 PM
teh CL's Avatar
Part number for the 2018 TLX V6 base ECU is.. 37820-5J2-C53
Also fits: ADV (V6), TECH (V6), TECH+A (A-SPEC RED), TECH+A (A-SPEC)
