Advance package really needed for heated seats?
Old 08-22-2016, 01:31 AM
darksky's Avatar
Did I read correctly that heated seats require both the Tech and Advance package???
Old 08-22-2016, 01:40 AM
RDX10's Avatar
I am pretty certain it comes on the base model. You probably just read it as part of the features list. No way Acura is that nickle and dimey
Old 08-22-2016, 09:35 AM
mrgold35
mrgold35's Avatar
Received 1,509 Likes on 1,177 Posts
You need the Adv model for cooled seat.
Old 08-22-2016, 01:37 PM
spoiler900's Avatar
heated is base, ventilated advance
Old 08-22-2016, 02:01 PM
darksky's Avatar
Great, thanks for the info.
Old 06-30-2022, 07:03 PM
altair47's Avatar
Everything is simple there, for maximum comfort, you need to unscrew the 2 front and 2 rear seat bolts, stop the seat in the middle, lower it to the lowest position, and bend the back 90 degrees, disconnect the negative battery terminal, disconnect the main seat connector, and the SRS connector. Then it is advisable to wrap the sharp ends of the frame with rags (so as not to scratch the threshold and door trim), and then carefully remove the seat. Put the seat on the table, take a picture of the bottom, remove plastic trim and slowly detach everything in the way, step by step, until you get the hooks that hold the cushion, remove the cushion, carefully remove the leather upholstery from the cushion, I had small latches, you can have metal staples (in this case, you come to cut all of them with the help of cutters and install ziptai in their place). This work should take 3-4 hours. If you've done this before, you'll be done in less than 3 hours.
gavriil
05-02-2024 11:41 AM
justinjsw
11-07-2023 07:42 AM
TSX69
09-06-2016 04:23 AM
brow
06-08-2016 06:16 PM
bsprinker
01-31-2016 02:16 PM
Quick Reply: Advance package really needed for heated seats?
