100k mile service
100k mile service
I was at the dealership for an oil change. The car has about 93k miles on it. The service consultant said I need the 100k mile tune up next time. The cost of this tune up is $1300 - $1400 and it includes replacing the following: 1) water pump, 2) serpentine belt, 3) coolant flush and 4) spark plugs.
Does this sound right?
Do I really need to change the water pump even if it's not broke ?
Thanks!
2015 TLX Base FWD, 4 cylinder.
Thanks!
YES it's called preventive maintenance. If you don't change the water pump along with the service and it goes bad they have to take everything apart to remove it and you'll just be paying double in the long run.
NO
You have a 4 cylinder that has not timing belt sheesh - frustrating they didn't look up what vehicle you have.
Just follow the maintenance minder codes. Change the spark plugs yourself with OEM plugs.
I wouldn't change out the water pump as preventative, if not leaking.
