Would these rims fit?
Hi, i'm looking for winter rims for my 09 FWD TL and came across these rims with the following specs:
8Jx17H2
Offset:20
PCD: 5x120
HH: 74.1
would these fit/be suitable? Thanks for the help.
8Jx17H2
Offset:20
PCD: 5x120
HH: 74.1
I just know that the bolt pattern is correct, but the offset and HH is not exactly the same as OEM...... does that make it OK to use still?
thanks.
Hopefully some other experts will chime in but that offset looks way too low. The wheels will stick out further than stock. I was researching the stock wheels and I think they're in the ET50+ range so you'll be out by at least 30mm which is a lot for wheel.
