Will the 20" wheels from the 2010+ Camaro fit our 2009+ TLs
Old 06-06-2015, 09:41 AM
awdflush's Avatar
Hello all, I have been doing some research to see if this setup would work on our cars but so far I have not came across any TLs using this setup. On the other hand, there are a couple of posts over on the Acura MDX forums showing that the wheels work on their cars.
The specs of the TL SH-AWD wheels are 18"x8" with +55 offset and 5x120 bolt patterns cb = 64.1
The Camaro wheels are 20"x8" +35 offset on the fronts and 20"x9" +40 on the rears with 5x120 bolt patterns cb =67
These wheels are OEM and are selling pretty cheap ($500-$400) on Craigslist. The tire setup I thinking of using would be 245/35/20 all around with Tein coilovers for the drop.
Whats your take on it and do you think its a direct fitment without any rubs or needing to roll fenders?
Here is how they look on the car.
This is up close.
spytter (10-16-2015)
Old 06-06-2015, 11:58 AM
David_Dude
Acura_Dude's Avatar
Yes. There's a member here who has CV3's on his 4G TL. IIRC the specs on those are 20x9 et35, no modification either. I'd go with the same size/width all the way around. That's just my preference though. Good luck, nice choice!
Old 06-06-2015, 03:09 PM
awdflush's Avatar
Thats all I need thanks!
Old 06-07-2015, 07:19 AM
wreak's Avatar
Don't forget you'll need hub centric rings for them to mount correctly. Definitely post pictures if you do this!
Old 06-07-2015, 09:01 AM
David_Dude
Acura_Dude's Avatar
And welcome to the forums.
Old 06-07-2015, 12:02 PM
BROlando's Avatar
Received 1,167 Likes on 877 Posts
I installed a set of 20X10 (+35?) with 275/35/20's on a 4G TL SH OMG AWD BBQ. The rear lip just barely needed a touch of roll. Like...another 3mm, and it would be clear. Also installed Tein SA's at the same time to lower it.
Old 06-07-2015, 04:15 PM
awdflush's Avatar
Great info and once I get them mounted I will snap some pics. Thanks.
Old 06-07-2015, 04:18 PM
awdflush's Avatar
Thanks Acura_Dude. Great forum with a lot of info on this car.
Old 06-10-2015, 01:15 AM
KenB350z's Avatar
Hmmm..
Old 07-06-2015, 09:04 PM
awdflush's Avatar
Wheels have arrived. Got them at $300 for the set with lug nuts and center caps. I will be painting them glossy black this weekend .
Old 07-07-2015, 08:27 AM
wreak's Avatar
Thanks for the update, can you weigh them before you install the tires? Definitely post some pix when installed.
Old 07-07-2015, 11:59 PM
awdflush's Avatar
^^ Yeah no problem. The 8" rims are 30lbs and the 9" rims are 32.5lbs.
Old 07-08-2015, 02:39 PM
HeartTLs's Avatar
Frickin anchors.
justnspace (07-08-2015)
Old 07-08-2015, 02:46 PM
Received 16,260 Likes on 11,971 Posts
"All Aboard!"
Old 07-08-2015, 09:21 PM
awdflush's Avatar
Yup, they sure are heavy.
Old 07-08-2015, 09:33 PM
wreak's Avatar
Acura oem HPT 19" wheels weigh 32lbs each so those numbers aren't that bad if you ask me.
Old 07-08-2015, 10:21 PM
awdflush's Avatar
Its usually what you expect with OEM wheels. They are durable but you pay the price in weight or money if you have a forged OEM wheel option like my previous EVO. I will try and post some pics once I have done painted them.
Old 07-09-2015, 06:37 AM
damaged442's Avatar
I can't say I ever thought about a Camaro wheel on a TL. I am curious to see how this pans out...
Old 07-11-2015, 03:21 PM
awdflush's Avatar
A lot have happened today....
I finished painting the wheels and they came out great. I used Dupicolor Satin Black and Matte Clear.
I covered the center caps with some 2.25" Acura decal.
Old 07-11-2015, 03:31 PM
millimac247's Avatar
Looking good. Definitely want to see the final pics of this.
Old 07-11-2015, 04:52 PM
awdflush's Avatar
Thanks. I will be updating this thread right up until the wheels are mounted .
Old 07-11-2015, 05:01 PM
awdflush's Avatar
The lugs for the Camaros are the same thread pitch as our Acura TLs 14x1.5. I went ahead and purchased a set of Gorilla Locking Lugs Wheel Locks Part# 71643NBC. It had a lot of great reviews and fits all 2010-2015 Camaro wheels.
Old 07-13-2015, 09:03 AM
SirCarroll's Avatar
I would get actual Acura center caps if they fit. The Chevy symbol is still quite visible and takes away from the look.
Old 07-14-2015, 12:57 PM
HeartTLs's Avatar
Wrong, they weight a tad over 28lbs, I weight them myself and verified. I've also weight 12+ 18's, 09-11 18's and diamonds.
Looks great, better than I imagined, so does the decal.
I'm sure from a short distance away it wont be visible and that most likely an acura center cap will not fit, hence why he did that.
Old 07-14-2015, 01:02 PM
maybe he could even sand or take off a layer from the bowtie emblem on the centercaps
if they are being covered with a sticker, then it shouldnt matter what it looks like underneath!
HeartTLs (07-14-2015)
Old 07-16-2015, 10:07 AM
SirCarroll's Avatar
This
Old 07-16-2015, 08:13 PM
ej6sliver's Avatar
Any pictures on the car?
Old 07-16-2015, 09:40 PM
awdflush's Avatar
Most Acura caps are 2 3/4, I need atleast 2 1/4. I found some blank after market caps but I was not planning on spending $50+ and then still having to use the Acura stickers on them.
Old 07-16-2015, 09:41 PM
awdflush's Avatar
Yup, once I install the wheels
Old 07-16-2015, 09:51 PM
awdflush's Avatar
I found this pic over on mdxers.org/forums/. I am curious to see how it would look on our cars, soon
Old 07-17-2015, 08:37 AM
HeartTLs's Avatar
Looks good on the MDX!
Old 07-22-2015, 04:36 PM
ej6sliver's Avatar
That looks really good on a MDX as well.
Old 09-03-2015, 09:59 AM
aleo12's Avatar
Any pics of the rims on the 4G TL?
Old 09-03-2015, 01:31 PM
HeartTLs's Avatar
Goddamn these teases.
Old 09-14-2015, 02:25 PM
sigbrown1297's Avatar
Update?
Old 09-21-2015, 09:22 AM
black asimo's Avatar
Old 09-21-2015, 10:10 AM
aleo12's Avatar
Originally Posted by black asimo
Looks wicked! Any need to roll fenders or anything to make them fit?
Old 09-21-2015, 11:43 AM
They fit perfectly, You don't need nothing, even a hub centric ring.
Old 09-21-2015, 09:10 PM
BDoggPrelude's Avatar
Did they fit on the front too and are those studded snow tires?
Old 09-22-2015, 03:58 PM
HeartTLs's Avatar
Asimo can you post a full side profile picture please?
Quick Reply: Will the 20" wheels from the 2010+ Camaro fit our 2009+ TLs
