wheels fitment.
Yikes - that seems like an aggressive offset with a really wide tire. If the calculator I used is any indication, I think the default tire/offset is 8in wide and +55. So if you use those tires it's going to stick out about 1.7in from stock... Those will almost certainty rub if you lower.
i really don't understand offset that well. how far off from the OEM offset can i go without rubbing giving that i don't lower my ride.?
if i use this rim setup, then what will be the best tire profile?
thanks for the help.
JByron
01-08-2016 09:49 PM
