Wheel bolt pattern question
Boring Teacher
So...I was under the assumption that any wheel for the 2009-2011 TL will fit a 2012 TL. But...I'm finding wheels from the 2011 TL-AWD that say they are 5 x 114 bolt pattern. I though all 2009-2012 TL's were 5 x 120?
Please help me! UGH!
no, 4g TL's are all 5x120 bolt patterns, regardless of awd/fwd. Ridgeline/odyssey/RL/4gTL/MDX/ZDX/10+pilots all use the 5x120. The rsx/accord/crosstour/civic/tsx/ use 5x114.3
6G TLX-S
Agree. All 4G TL's (MY '09 -> current) are using the bolt pattern of 5x120.
it is possible that someone may have redrilled the wheels if theyre used. its even more likely that an online store is using old numbers and just guessing the bolt pattern since the previous gen was 5x114. thats just my $0.02
http://carphotos.cardomain.com/ride_...4006_large.jpg
http://i1176.photobucket.com/albums/...s/IMG_1803.jpg
6G TLX-S
The 4G TL has a wheel bolt patten of 5x120. I've bought aftermarket wheels for the car, and only the 5x120 wheels fit.
If you see 5x114.3 wheels installed on 5x120 cars, they must be using bolt pattern adapters.
2010 MDX 19" wheels are 5x114. I've seen them on a 96 RL, and a 04 TL. So must be 5x114! No?
filled and re-drilled.. thats all that is.
i have a 2012 acura tl. bough aftermarket rims that are 5x120 - they won't fit. Does anyone have a 2012 acura tl SHAWD tech package and know what the bolt pattern is?
searched all over the internet with no luck
The inconvenient truth
As clearly stated earlier in this thread, all 4G TL are 5x120. If your car isn't then it must have been modified. Or the wheels you bought aren't actually 5x120. That seems most likely. The wheels should have the bolt pattern stamped somewhere on the inside of the wheel. Check that first to confirm.
thank you guys
6G TLX-S
Pictures please.
DunesCreations
09-09-2015 12:03 PM
