Tein coil overs
Old Feb 14, 2013 | 04:29 PM
sdelia's Avatar
Tein coil overs
Hi every one, I currently have my tl lowered on h&r springs, but want to change to a coil over set up this spring.
I need opinions, tein basics or ss, and also with both do you still have to use your oem top mounts or do either come with the top mounts? And are rear camber arms completely necessary when using the coil overs, or it depends how low I go with them?
Any feedback would be great! Thanks in advance.
Old Feb 15, 2013 | 09:46 AM
Alexander.'s Avatar
Neither the tein basics or ss come with top mounts, you need to reuse the oem bits and pieces to complete the setup.
Rear camber arms will depend on how low you plan on going.
Old Feb 15, 2013 | 10:01 AM
Excelerate's Avatar
Former Sponsor
The TEIN Basics and SS require you reuse your top mounts. If you're going to spend the money I'd recommend getting the SS so you can adjust the damping to the level of firmness appropriate to you.
The rear camber/toe arms may be necessary depending on how low you go but you'll need to get an alignment to find out for sure.
If you want a coilover that comes with top hats but is softer like the TEIN's get our XLR8 ISC coilovers in the Street/Comfort setting:
http://store.excelerateperformance.c.../i-528366.aspx
Old Feb 16, 2013 | 11:38 AM
manutd's Avatar
Sorry to thread jack but are the XLR8 ISC coilovers a comfy ride or stiff? Ive had BC coils but im looking for something a little bit comfy...
Old Feb 18, 2013 | 12:17 PM
Excelerate's Avatar
Former Sponsor
I wouldn't call them comfortable. If you get the Street/Comfort setup though it is fairly street compliant and "comfortable". Our XLR8 ISC coilovers use an aluminum top mount so it won't be as soft as the OE or TEIN suspension which use top mounts with rubber bushings.
Aug 15, 2019 12:58 PM
TLrascal
Aug 3, 2018 11:00 PM
lidobitesize
18
Oct 22, 2016 10:21 PM
BoricuaTL
Apr 8, 2016 01:08 PM
TSX 09
33
Oct 25, 2015 01:32 AM
