SPC vs Ingalls rear camber kit
Any recommendations here? It looks like Ingalls uses a ball joint and arm, whereas SPC uses 3 arms. Which is easier to align? I would assume that the 3 arms would be easier to install than pulling the ball joint, even though I have access to a ball joint spreader.
My toe is way off, so I need to order something soon.
SPC: Specialty Products Company | SPC Alignment | The Automotive Alignment Leaders
Ingalls: 35623 - Rear Camber/Toe Kit - Ingalls Engineering Co., Inc.
The Ingalls kit allows for + or - 3 degrees of toe adjustment, whereas the SPC kit only allows for + or - 1 degree of adjustment. If your toe is really out of spec, you'll be better off with the Ingalls kit. We have the kit available on our website for $145.84 per side.
Ingalls Alignment Kit - Excelerate Performance - Japanese and European Performance Specialists!!
I plan to buy the SPC kits once my bday rolls around (end of Aug). I'm not a fan of the slight negative camber I have in the rear and want it to be the same as the front (@ -1.5; currently rears at -3.2 & -2.7).
It should be fun trying to get the ride height equal again, front and back. It seems like it will be tough since adjusting the height will affect the camber, and when that's fixed it will affect the height.
I will say it takes time and patience to adjust the Ingalls ball joint (because it's in a very tight spot) and less time and effort for the SPC kit because the arms are around an open location and easily accessible for the tech. I've had several shops work on my car and all of them came out sweating taking at least an hour to get it within specs lol.
09-04-2015 08:03 AM
nuldabz
09-03-2015 05:49 PM
