quick question bout size rims for daily driver
Old Nov 2, 2016 | 02:32 PM
Dakydd's Avatar
I have a 2010 acura tl shawd...looking at a set of 20x10 (square) offset 35 tsw rouen in black...what size tire would i need to run...and would i need to add 5mm wheel spacer...also i enjoy spirited back road drives would that be to wide of a wheel? Also no plans to lower anytime soon...may next spring\summer...
Old Nov 2, 2016 | 02:35 PM
anything over 9 inches wide is over kill
and why not learn to spec your tires correctly, by going to Tire Size Calculator - Tire & Wheel Plus Sizing
then there are wheel offset calculators. you can then input the offset and the calculator will spit out if you need a spacer or not..
as all it is, is math.
Old Nov 2, 2016 | 10:54 PM
carbonTSEX's Avatar
The Original Shawdy
You can use those specs and be fine. I would personally run 245/35/20.
The only reason why you would need to run a spacer is if it's an O Disk rim which gives max lip but sits close to the brake caliper. Really depends on rim design.
00TL-P3.2
Feb 11, 2019 11:23 AM
lowther420
ILX Audio, Bluetooth, Electronics & Navigation
Nov 7, 2016 03:31 PM
Sep 19, 2016 11:37 AM
