OEM 18 inch wheels
Old Feb 27, 2011 | 08:58 PM
cl0ud8888's Avatar
OEM 18 inch wheels
hey guys
im just wondering what tire pressure is the best setting to get the best ride out of our car......i have the 18 inch oem gunmetal wheels
cold pressure?
warm pressure?
Old Feb 27, 2011 | 09:10 PM
cl0ud8888's Avatar
anyone?
Old Feb 28, 2011 | 03:17 PM
ffiallo's Avatar
I use 35-36 psi all around, as I prefer the harder ride and better gas mileage - cold, as they heat up they go up about 3 psi.
Old Feb 28, 2011 | 03:48 PM
JM2010 SH-AWD's Avatar
I keep them at the recommended 32 cold. As previous poster said, once they warm up, they're running about 35-36.
Old Mar 1, 2011 | 08:04 AM
GunnerX's Avatar
Acura has already done all the testing necessary to get the best performance with OEM specs. The tire pressure is stated on the sticker on the door frame.
Old Mar 1, 2011 | 11:48 AM
jspagna1's Avatar
The Sicilian
I run 34 psi all around.
Old Mar 29, 2011 | 08:27 PM
cl0ud8888's Avatar
my sticker says 32spi cold but car came with 17s....i bought the 18 gunmetal thats why im wondering
Old Mar 29, 2011 | 08:48 PM
Mr Marco's Avatar
32 psi is typical. I have run 30psi on the RDX for 4 months now and will go up to 32 now. A hard core fanatic I know runs 35 on his Toyo Proxes 1’s and insists that this is the proper psi for a high performance tire on a Honda.
Running to low will cause excessive heat and feather the edge of the tire. Running to high will give a rough ride and cause more wear in the center rib.
Go with 32psi. (19" HPT on our TL is 37psi-Front 32psi-Rear)
mtl_ilx
Sep 3, 2015 09:58 PM
Snafunk
1/2G MDX (2001-2013)
Sep 3, 2015 08:01 PM
mtl_ilx
Sep 3, 2015 09:48 AM
MyKids&Cars
Sep 2, 2015 12:03 AM
MyKids&Cars
Sep 1, 2015 12:53 PM
