Help with wheel sizing please
Hey all, just wondering if a 20x9 with a 20mm offset would fit on my 2010 tl without any rubbing. I will be using a 245/35/20 tire on the rims on all 4 corners and not planning to drop the car at all in the future. Any input would greatly be appreciated. Thanks in advance.
Dont think it will rub if you dont drop it but 20mm offset will def be sticking out of the fenders and might look a little funny. I have 20x9 with a 35mm offset and it is pretty flush. For the 4G I would say anywhere between 35-45mm offset is ideal.
That's a pretty aggressive offset and I agree you shouldn't rub if you don't lower it. But it's going to look quite odd with the tires probably sticking out past the fenders. Based on the OEM offset of +55 on the 8inch wheel, moving to that offset will cause the wheels to stick out a little less than 2 inches from where they are now.
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
