Enkei RP03 5X120 19 X 8.5 42 Offset
Im looking at a set of these for my summer wheel's since im dying inside of looking at the stock 17's. I also plan running on Nitto NT05's 245/40/19. Will these setup fit with no rubbing since i'm dropped about 1.2 inches and will i be able to install a new set of TMPS sensors?. I'm also open to different tire suggestion's. Thank You ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
http://www.enkei.com/images/race-ser...lver_large.jpg
^ Link for a picture of the Enkei's
Nice pick. I don't see any problem with rubbing, pretty much the same as my car (but i have 20's). You should be able to swap the TPMS sensors from the old tires if you're going to get rid of them, or buy new ones if you're keeping the 17s for winter tires.
I absolutely love these Enkei wheels...this is my first choice of wheels for my cbp 09 awd. I've been searching high and low for the SBC color. It's been impossible to find and I have to check into ordering them from Japan if possible.
It's a dark chrome look which I think will match the midnight chrome grill and rear trim perfectly. Please post pics once you get the wheels installed...would be great to see them!
Thanks!
Thanks!
OP...I suggest calling the seller/s to make sure this wheel / configuration is really available. I came across this wheel on many websites and although they showed it as available when I called I was told it was not. Although I was mainly looking for the SBC color...I was advised by wheelsnext that in silver the only one available was with the 35 offset, not 42.
The guy i spoke to a vividracing said it wouldn't fit without a spacer but i'll probably be ordering one wheel to check fitment myself because i was dead set on these wheels after a year of searching.
I suggest looking for pics on this site to see how a 35 offset looks. I believe most TSW wheels are 35 offset...so if you search that brand you might find some. I'm pretty disappointed too I can't get these wheels in the specs I want. It's ridiculous how so many websites show the 42 offset when it's really not even available.
So some people have been running 32 offset's on their 4Gs and they seem to be okay, so i ordered one wheel to check fitment myself. I'll post pics on car when they arrive.
6G TLX-S
https://acurazine.com/forums/4g-tl-tires-wheels-suspension-298/test-fitting-bbs-rg-r-19x8-5-et-32-base-tl-749145/
He ran the same size wheel with a 32 offset. Since the Enkei i ordered were 35 offset, i should clear the brakes with no problem.
6G TLX-S
https://acurazine.com/forums/showthread.php?t=749145
The guy in the above thread test-fit with a much smaller tire. Only when mounted and driven around with OEM size tires, then we can sure the tires won't stick too far out to rub the fenders.
neuronbob
23
07-16-2019 10:48 AM
vtec314
11-07-2015 08:20 AM
SinCityTLX
55
10-11-2015 01:20 AM
