Emotion Suspension Damper Coilover Kit Honda Accord / Acura TL UA8/UA9 J35 J37
Anyone heard of these?? apparently these are made in Taiwan, but company is based in japan.
http://www.ebay.com/itm/Emotion-Susp...bfe660&vxp=mtr
http://www.emotion-power.jp/index.html
Type Adjustable Suspension System 1 set
Car Honda ACCORD / Acura TL (UA8/UA9) Engine Honda J Engine
Year 2008~ Spring Rate F: 10 kg R: 6 kg
(Spring rate can be changed to other settings. Please inform us before buy it now. )
Ride High Adjust +10mm to -60mm
Uppermount F: Fixed R: Fixed
Body Type F: Mono-Tube R: Mono-Tube
Origin 100% Taiwan Made
Note Honda Accord and Acura TL have different suspension.
Please tell us which model of your car was, after you buy it.
Warranty 6 moths limited warranty
- 24 Levels of damping Adjustable
- 44mm Linear Characteristic Internal Needle Valve Piston
- JIS G3445-STKM13C (DIN2393-ST44-2) Carbon Seamless Steel 52mm Tube
- Lower Bracket Height Adjustable, prevent adjust the spring perch offering the maximum shock-absorbing travel
- 100% Brand New
thats not what makes it soo interesting.
most coilovers can scrape ground.
the ability to have a shorter shock body = you'll have full range of shock travel. without hitting the bumpstops.
with the koni yellows we have to slightly MODIFY the shock body to get the full range of travel.
Soul_Deamon
11-13-2018 04:44 PM
