centric full ceramic brake pads
How are the centric full ceramic brake pads? Anyone using them?
Are they better than OEM ? |
Anyone ??
too be quite frank, any pad will do you just fine......
if you are just looking to uprade to a ceramic pad, the centrics will be great for you. IIRC, Centric the brand is the worlds largest leader in aftermarket braking components...( a little googling would have shown you this) |
you have had an audi and have a bmw sports car....you dont know your braking stuff!?!??!?!??!?
your man card has been revoked |
:ohsnap:
#boughtnotbuilt |
(Post 15836643)
Your man card has been revoked |
:smooch:
I did some research and some place i read that ceramic brake pads has longer stopping power than OEM although the main advantage is less brake dust and noise, any thoughts on it?
I dont want to compromise on stopping power ? |
Originally Posted by boss2k
(Post 15842189)
I dont want to compromise on stopping power ? You can go with a ceramic compound that is more aggressive than stock or less aggressive, choice is yours! |
(Post 15842189)
I dont want to compromise on stopping power ? stopping distance relies MORE ON TIRES!!! traction is what stops your car. so, if you DONT want to compromise stopping power, you'll need to keep your tires in check, ALWAYS 2nd, as stated above, it comes down to the actual compounds of the pad. if you hate the dust of a carbon based pad, you'll love a ceramic pad. and guess what?!?! you wont even miss the initial bite of the carbon pad. |
(Post 15842329)
again, you have two or have had two race cars, wtf?! (I consider them race cars because they have more power than the average car. and I cant afford them)
stopping distance relies MORE ON TIRES!!! traction is what stops your car. so, if you DONT want to compromise stopping power, you'll need to keep your tires in check, ALWAYS 2nd, as stated above, it comes down to the actual compounds of the pad. if you hate the dust of a carbon based pad, you'll love a ceramic pad. and guess what?!?! you wont even miss the initial bite of the carbon pad. appreciate your responses. |
just giving you a hard time, as buying a sports car is a manly rite of passage. :poke:
and directly translates to pedestrian-commuter type cars. so, yes...you should upgrade to ceramic if you are tired of the brake dust. But this doesnt necessarily mean you'll suffer worse braking distances.. |
As JustnSpace said, it comes down to preference. If you're looking for less dust, go with the ceramic setup. If you want better heat dissipation for autocoss/track, or just more performance for the street, we recommend our para-aramid compound Stoptech package.
Acurazine Brake Packages ACURA - Excelerate's Honda & Acura Store - Japanese Performance Specialist https://cimg0.ibsrv.net/gimg/acurazi...09519989cd.jpg |
