Centering Ring??
I believe that means you need a hubcentric ring...
Wheel Hub Centric Rings are designed to fill in the gap between the hub of the car and the center bore of the wheel. Most wheel manufacturers design their wheels with a centerbore large enough to fit on most cars. Therefore, since wheel manufactures make their center bore large enough to fit most cars, most wheel fitments have a gap between the hub and the centerbore. This gap usually doesn't allow for the wheel to fit hubcentric but rather lugcentric which causes vibration. Therefore, to fill the gap and ensure the fitment is hubcentric, hub rings are used.
Most aftermarket wheels have larger-sized center hubs in order to fit as many types of autos as possible. Therefore a hub ring is required to bridge that hub size difference to ensure a vibration-free ride with the new wheels, unless the new wheels are specifically built for Honda/Acura vehicles.
>Offset: +45mm
Backspacing: 6.49
Bolt Pattern: 5-120
Rec. Tire Size: 245/40-19
BE GTS-AV wheel
>Offset: +45mm
Backspacing: 6.49
Bolt Pattern: 5-120
BE GTS-AV wheel
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
