Breyton wheels
Breyton wheels
All, I know these wheels are somewhat specific to BMW's, but I wanted to confirm if they can fit on our 4th gen TL's. The specs on the Breyton wheels I was considering are 19x8.5; 5x120, +35mm offset. Will these fit or do I need to look at others.
Thanks in advance for your insight.
Cheers,
Bryan
Cheers,
Bryan
The wheels will go onto the TL. BMWs have larger center bores, so you will need to get a hubcentric rings for them. If i remember correctly, 74.6 to 64.5. This is just off the top of my head, please confirm with your local tire guy, or research.
The offset is the thing you have to worry about. I tried on wheels with 32 yesterday, sits pretty darn flush with the fenders. if you are willing to roll the rear fenders, they will fit. If you add in negative camber, the will fit easy.
All,
Thanks for the input; it is well appreciated. I'm not sure if I am going to lower the car at this point so perhaps I'll be in decent shape given the +35 offset.
Again, many thanks,
Bryan
Again, many thanks,
Bryan
I looked at the Breyton wheels too. The research I came up with was that they are both 5 x 120, but the centerbores are different. Ours is apparently 64.1 and theirs are 72.56. Is there a way to make these work without having them redrilled?
You dont have to get the wheels re-drilled, there are hubrings that make up the difference in size you just have to find one thats 72.56 outside and 64.1 inside. A lot of aftermarket wheels have bigger bore sizes so they can fit different cars. Most wheel shops should carry them unless this is a wacky combination.
I have them on my ride
I have goodyear eagle GT tires brand new on 19's for my 05 tl. These tires absolutely suck feels like the rims are warped but it is just the crappy tires.
This thread is 4 years old...
Aaannd ^Your sig says you run TSW wheels???
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
JByron
01-08-2016 09:49 PM
