4G Wheel/Tire specs thread with pics
#281
#282
The following 4 users liked this post by RDXtremist:
#284
Repping the Bay Area, this bagged TL (owned by @ratatattattat on IG) on all new Vossen x Work VWS-3 looked super dope against the sunset....check out this short clip and then Vossen x Work - Vossen Wheels to order your set of these amazing 2 piece wheels by Vossen! Shout out to Cali Wheels!
Acura TL (3rd Gen)
VossenxWork VWS-3
Finishing Details: Polished Anodized Lip/Gloss Bronze Center
Wheels are 20x10.5 and 20x10.5 wwwvossenxwork.com
Check out our current Vossen line by clicking HERE
Configure your Acura using our all new Vossen3D Configurator.
Click HERE to view the full album.
Acura TL (3rd Gen)
VossenxWork VWS-3
#288
1.Brand of Rim - Verde Axis Bronze
2.Rim size (diameter and width) - 20X9
3.Offset - 35MM
4.Brand of tire - Dimax
5.Tire size - 245/35/20
6.Drop Type and Amount - Tein Street Advance Z
7.Do they rub - No
8. Transmission type - AT
TLmatt (09-20-2018)
#290
4th Gear
I love the drop on your acura. Looks like on the picture no fender rolling. How much did it settle compared to stock? Did you go with Tein recommended settings?
#292
Thanks. Correct no fender rolling front fender is factory rolled on 4th gen's. -2 degree camber in the rear prevents rubbing its close. I am sure if I got the camber kit I would have to roll the rear fender. I dont know how much it settled as I never measured it. I took the coilovers to my local shop I can only assume they used Tein recommended settings.
#293
The inconvenient truth
Yeah you can use the natural camber from lowering to fit without rolling the fenders but the tires will wear faster. I also like the look. Fyi tiens recommended drop is aggressive while it's recommended dampening is not. Best off to lower it however much you like and play with the stiffness if you get the street advance.
bigwavedave25 (04-08-2020)
#294
HELP! Clueless newbie bout drop cash on 20" Vossens!
I've got money burning a hole in my pocket but I'm so afraid of making a mistake and buying the wrong offset. I've got a 2009 TL SH-AWD and unfortunately I'm stuck with the tires that Les Schwab sold me which are Toyo Proxes 4 - 255/35/R20 because they're almost brand new I just gotta make em work. But I'm now reading that perhaps they're not the best for obtaining the flush look I'm going after with the Vossen CV3's. If I have to buy the Tien Coilovers and/or roll my fenders that's fine with me! I have a friend who's eager to help and knows how to do all of that. But am I screwed with these tires or can I make them work? And if so, how wide should and which offset do I select to achieve this look or as close as possible....and with minimal fender rolling? The photo posted here with the Vossen Banner is what I'm going for. The other two photos I grabbed from this forum to show the type of fitment I'm trying to achieve. I don't want the rim pushing way out, I like that clean flush look. Any help would be greatly appreciated. Nobody seems to help when you go into tire shops. They're clueless and/or can't sell me what I'm wanting due to liability reasons
This is what I want my Black TL to look like!
This is the fitment I'm looking for and these Vossen Wheels are very close to the CV3's I'm about to purchase
This looks KILLER in my opinion! And also doesn't look like much rubbing issues either.
#295
Do you see the post above yours? Thats my car with the exact same tires. Toyo proxes 4 plus 255/35/20, mounted on 4x TSW 20x9 + 35.
So you can make them work if you have to. My fenders are not rolled. The fronts are fine but the backs only fit due to being at -2.5 camber and yes they do rub a tiny bit on occasion. Nothing major though.
Is that close to what you want?
#296
I just bought my car 2010 TL FWD in October so a little late for the query below about the Hankoks....But the 245/50/17 Hankok Optimos (almost new that came with the car) suck wind! Hydroplane even at low speeds with just a little moisture on the roads and I can't wait how pathetic they will be in winter snow. I am looking for a used set of 245/45/18 Alpins for a trade for my GTI's 235/40/18 Michelin Alpins that are barely 2 winters and under 8000 miles old.
Wondering what effect a slightly narrower tire 235/40/18 vs. 245/45/18 will have on the TL if I get a set of 18" rims for it. Any insights?
#297
Gire (09-13-2023)
#299
#300
1.Brand of Rim - FastWheels
3.Offset - +35mm
4.Brand of tire - Cooper
5.Tire size - 245/45R18
6.Drop Type and Amount - Stock height
7.Do they rub - No
8. Transmission type - 5AT
3.Offset - +35mm
7.Do they rub - No
The following 2 users liked this post by Unknownerror0010011:
Gire (09-13-2023),
real_mckoy (02-12-2020)
#301
1.Brand of Rim - Niche Form (charcoal)
2.Rim size 20x10 all around
3.Offset - +40
4.Brand of tire - NITTO INVO 555
5.Tire size - 255/35/20
6.Drop Type and Amount - Tein SA
7.Do they rub - Fenders rolled 1/2 way, rubbs a little, need to roll the fully.
8. Transmission type - A/T
3.Offset - +40
Do you get any vibrations running tires that wide?
#302
3.Offset - +40
3.Offset - +40
#303
1. Brand Of Rims: Enkei TY-5 Pearl Black
2. Size Of Rims: 19x9.5
3. Offset: +35
4. Brand Of Tire: Firestone Firehawk Indy 500
5. Tire Size: 245/40
6. Drop Type and Amount: Tein Street Advance
7. Do they rub: No. Rear fenders rolled.
8. Transmission type: Auto
Thanks to Soal Man for helping me with choosing these wheels!
3. Offset: +35
#304
Did you have to camber your back tires ?
I'll contribute to this thread.
1.Brand of Rim - Niche Verona M150
2.Rim size (diameter and width) - 20x10.5
3.Offset - +35
4.Brand of tire - Toyo Proxes 4 Plus
6.Drop Type and Amount - Tein SS
7.Do they rub - Occasional on big dips going fast; fenders rolled
8. Transmission type - 6MT
9. Picture - Attachment 47385
3.Offset - +35
#305
[QUOTE=brandon7583;14709785]We needed a Wheel/Tire specs thread with pics for 4Gs
Please everyone list your set ups (no stock set ups)
1.Brand of Rim - Niche Gamma
2.Rim size (diameter and width) - 20x9
3.Offset - +35
4.Brand of tire - continental Gmax
5.Tire size - 255/35/R20
6.Drop Type and Amount - none
7.Do they rub - no
8. Transmission type - Auto
9. Picture -
The following 3 users liked this post by Ahmer Jaleel:
#306
1.Brand of Rim - Milanni Tycoon
3.Offset - +42
4.Brand of tire - Durun
5.Tire size - 255/35R20
7.Do they rub - No
9. Picture -
3.Offset - +42
7.Do they rub - No
9. Picture -
#307
1.Brand of Rim - VS Forged
2.Rim size (diameter and width) - 19x8.5
3.Offset - +40
4.Brand of tire - Michelin Pilot Sport A/S 3 Plus
5.Tire size - 255/40R19
6.Drop Type and Amount - Tien Street Advance
7.Do they rub - No, rolled in rear
9. Picture -
3.Offset - +40
9. Picture -
The following 2 users liked this post by Christopher Michael:
bigwavedave25 (01-06-2020),
Gire (09-13-2023)
#308
Perfect size...
3. Offset: +35
3. Offset: +35
Soal Man (01-09-2024)
#309
Rohana RC9
- Rohana RC9, 20X9 +35 Offset with 245/35R20 extreme contact tires on all four corners
- Dropped approx 1 inch on fortune auto 500 series coilovers
- Truhart adjustable upper control arms up front, SPC adjustables in rear.
- No rub at all with this setup
#310
Simple but effective...
I haven't seen anyone with wheels like mine, on a TL. Maybe I am the first, or the first in my area.
For people who are wondering why I made this choice;
0) Presentation/Looks: I don't like the look of big wheels with small looking brake rotors and calipers.
1) Weight: Big wheels are usually heavier, which slows acceleration. Unless you spend some good money on VS Forged, OZ or something lightweight. My wheels are almost 7lbs lighter than stock. Stock wheels weigh 25.2lbs
2) Ride Quality: Bigger wheels tend to decrease ride quality due to less tire travel or deflection. Smaller tire sidewalls absorb less bumps, and in my area potholes are deepppp....
3) Cost & Fitment: They are affordable, work with stock tires, and near/same stock handling. I wanted my wheel offset to be close to stock.
After months of research, and more research I made my choice. So do your homework before purchasing wheels for your car.
1.Brand of Rim - Apex Wheels
2.Rim size (diameter and width) - 18 x 9.5
3.Offset - 58
4.Brand of tire - Continental PureContact LS
5.Tire size - 245/45/18
7.Do they rub - Nope
8. Transmission type - HondaMatic
9. Picture -
3.Offset - 58
9. Picture -
#311
1.Brand of rim - BMW STYLE 95s
2.Rim size (diameter and width) - 19x9 square setup
3.Offset - +24
4.Brand of tire - Goodyear
5.Tire Size - 245/40/19 all around
6.Drop type and Amount - TEIN SA. 1”
7.Do they rub - on dips ( need to roll my fenders)
8.Transmission type - AT
9.Picture -
3.Offset - +24
9.Picture -
The following 2 users liked this post by real_mckoy:
bigwavedave25 (03-06-2020),
vertigo2 (02-13-2020)
#312
1.Brand of rim - BMW STYLE 220(E92 or 08-10 M3)
2.Rim size (diameter and width) - 19x8.5 or 9 I can't remember but was a staggered setup
3.Offset - idk
4.Brand of tire - Continental Extreme
5.Tire Size - 225/35/19 front 255/30/19 rear
6.Drop type and Amount - Stock
7.Do they rub - no rub
9.Picture -
3.Offset - idk
9.Picture -
Gire (09-13-2023),
Unknownerror0010011 (01-17-2021)
#313
Unknownerror0010011 (02-09-2021)
#314
Hey
[QUOTE=Ahmer Jaleel;16432580]
whatsup brother, I’m in the verge of getting the exact same setup, I know you said it doesn’t rub, just want to know if It hasn’t rubbed at all since you posted this last year?
3.Offset - +35
7.Do they rub - no
9. Picture -
3.Offset - +35
7.Do they rub - no
9. Picture -
#315
[QUOTE=Clout Lord TL;16543716]Hey man thanks for looking and replying, since iv had them on I found the rears do rub a little on dips with just me in it and when loaded it rubbed alot but I just rolled the rear fenders and I don't have that problem anymore. The fronts are not a problem at all but rears have a natural camber making it rub hope this helps!
#316
[QUOTE=Ahmer Jaleel;16543894]
Got you brother, thank you very much for that, do you mind posting a couple of updated pictures with the fender rolled? I’d really appreciate it
#317
[QUOTE=Clout Lord TL;16543943]For sure I live in Ontario Canada so it's winter now I have my winters on but as soon as spring comes around I'll be sure to do that!
#318
1.Brand of Rim - Ron Jon
2.Rim size (diameter and width) - 20/8.5
3.Offset - 40
4.Brand of tire - Pilot Sport
5.Tire size - 245/35-20
6.Drop Type and Amount - Springs 1.5
7.Do they rub - No (Rolled)
8. Transmission type - AT6
9. Picture
2013 TL
3.Offset - 40
9. Picture
2013 TL
#319
1.Brand of Rim – Work VSXX
2.Rim size (diameter and width) – Front 20x9/Rear 20x10.5
3.Offset – Front +16, Rear +25
4.Brand of tire - Nitto Invo
5.Tire size – Front 235/30/20 , Rear 255/30/20
6.Drop Type and Amount – BC Racing Type BR 12k/8k w/extreme drop kit (no where near maxed out!)
7. Camber kit/fender work? Ingalls rear camber/toe kit. No fender rolling.
8.Do they rub? Nope
9. Transmission type – 6spd auto
10. Pictures: enjoy!
Attachment 47304
Attachment 47305
Attachment 47306
Attachment 47307
Attachment 47308
8.Do they rub? Nope
Attachment 47304
Attachment 47305
Attachment 47306
Attachment 47307
Attachment 47308
#320
AG Forged 510's 20x10 ET27...
Tires Proxy 4's 255 35 10
Lowerd on Tien SS with Edfc
Rubs on driveway entrance when the rear is flexed... Some fender work done ... But I'm getting more done to them because I want a flush look no gap. The front is OK but the rear rubs if I drop it any lower. Also running Hella camber -3.0... And not feeling it. Do you guys think I can go lower and bring camber to within spec without having major body work done? Don't want to go thorough the whole flare and paint business $$$$.
