30 series front, 35 series rear
My brother is putting on some 19's on his car..
wondering if there is any problem running 30 series front and 35 series rear? he wants a little more meat in the back..
this will be on a 2012 accord coupe.
when some one wants more meat in the back, they generally go for a wider look.
your brother, however, is changing the profile height and not the width.
it will look AWKWARD, a lower profile in the front and a thicker sidewall in the back.
I'm not to sure why he's doing this.....
Unless he is stretching tires.
usually, a stretch is still lowering the profile and width....
Please post tire specs.
lol.. i dunno.. i asked him why.. he just said he wants to.. he just wanted me to ask.
but the question remains.. will this cause any problems
hes running 245/30/19 and 255/35/19..
When you are considering changing the wheel and tire size on your vehicle, the important thing to remember is that the overall diameter of the tire/wheel combination should be close to the original sizing.
To find out the overall diameter of your original tire/wheel combination the first thing you must be able to do is read the tire:
Example:
225/40R18
225 – Section Width in mm (Section Width or Tire Width is the measurement of the tire from sidewall to sidewall)
40 – Section Height/Aspect Ratio (Aspect Ratio is the ratio of the height of the tire’s cross-section to its width. In this example, 40 means that the height is equal to 40% of the tire’s width. This is also sometimes referred to as “Series”.)(profile)
R – Construction (The "R" stands for radial, which means that the body ply cords, which are layers of fabric that make up the body of the tire, run radially across the tire from bead to bead. A "B" indicates the tire is of bias construction, meaning that the body ply cords run diagonally across the tire from bead to bead, with the ply layers alternating in direction to reinforce one another. Newer tires also have new sport constructions, such as Z. See your preferred tire manufacturer’s website for details.)
18 – Wheel Diameter (18” diameter)
Sometimes your tire will have a letter in front of this information indicating “P” for passenger car or “LT” for light truck.
Formula for Calculating Tire Dimensions
Using the above example once again - 225/40R18
1. 225 mm divided by 25.4 = 8.86” (section width)
2. Multiply 8.86 (section width) by .40 (aspect ratio) = 3.54” (section height)
3. Multiply 3.54 (section height) x 2 then add the rim diameter (18) = 25.08” which rounds up to 25.1”.
25.1” would be the tire dimension for this particular example.
Tire Size Calculator
http://www.motegiracing.com/techzone...me=totaltech1#
sKepz (10-01-2012)
so in other words, the width and profile height go hand in hand.
your Original post is incomplete and missing info.
your brother wants a wider tire while keeping the same rolling diameter.
use the calculator to find out what tire comes closest to stock.
ALSO, WHY THE FAWK DOES HE WANT WIDER IN THE REAR!?!
FWD vehicle...
FWD vehicle...
This will just add more unsprung weight and drag on the front end. Unless he's getting them for free, he should stick with 245/40/19.
6G TLX-S
Wider tires on the rear of a FWD car will further increase the understeer tendency of the already defaulted understeering front-heavy FWD car.
Not a good move, unless the car owner want his/her car to handle like crap.
Mr Marco (09-25-2012)
BTW.. total diameter of wheel including tire is smaller on the front than the rear as well, so his car will look funny.
And as Edward TLS said he would be negatively impacting his handling especially since his car is FWD. If it was SH-AWD this would matter less as the torque vectoring quality would be able to utilize the increased rear tire width to push the car around the corner.
