265/40/18 tires on OEM 18" rims?
Running 32-33 cold PSI. Seems to work pretty well.
Guest
Posts: n/a
No. I just want the maximum contact patch possible. I had a chance to air out the car on some twisties this afternoon and it was amazing. I actually like it better than the ZR1 because if I even twich in that car, I'm putting my life and someone else's in danger. In the TL, the SH-AWD is truly awesome. Basically turn to the traction limit and then ease into the gas and over drive the car. That is opposite from everything I have ever known. I can steer the ZR1 with the throttle, but in a 4000 pound car with a 59% front weight bias? How is that possible? The engineers at Acura are some smart dudes for sure! I am wondering how the TL would handle with more contact patch.
The TL is no drifter, but it is simply fantastic. The ZR1 is a beast and you better know what you are doing or you are a dead man. My joke is it is 0 to your grave in 4 seconds. The moment you don't respect that car, you will not get another chance to see day light. By far in comparison the TL is tame and utilitarian. Lots of fun.
WDP 4G
what tire is on the ZR1?
and we love pictures.....
especially vettes
AZ Community Team
Received 7,771 Likes
8 inch, 8.5 inch or 9 inch rim?
If it's 8 inches it's narrow for a 265 section width tire. A lot of people and/or installers will say it's too narrow.
Guest
Posts: n/a
The ZR1 has Michelin Pilot Sport PS2 ZP tires with 285/30ZR19 on the front and 335/25ZR20 on the rear. It is more than $2000 for a set of four. The longest burout I could muster was 465 feet and then I ran out of road. I probably burned a few hundred of dollars in that one session. Without the traction control, I can light them up in first, second and about 2 seconds into third. Of course the fastest acceleration is with minimal wheelspin.
The TL has OEM Michelin 245/45/18 tires. I was considering the Continental ExtremeContact DWS. I had them on my old TL and they were great! Even if the 265/40/18 tire size is not possible on the TL, that is fine. I would likely change to the Conti tires when the OEM tires wear out.
I've put 37k on the oem tires and they still have a lot of life left so you'll be waiting for a long time..
If you want 265 width, you'll probably need 9j wheels at least, and lower profiles like a 35 or 40 probably. When I was looking for new wheels, I was looking at 20x9j with 255-35-20 to minimize the difference.
OP,
You should run the recommended PSI. The 10-20mm difference in width between the stock size and the 255-265 will be negated by the load change (assuming the contact patch size increases…and this has been over-debated). The only difference you will notice is in your wallet for more gas (due to the drag and higher roll resistance from the wider tire) and more expensive rubber ($365 more [PS2 245/40-19 vs. 255/35-20] for a set of Michelins). Ya, it will look hot with the 20's but you already have a hot car...
SAVE YOUR MONEY
Guest
Posts: n/a
^Good adviceHowever...
OP,
SAVE YOUR MONEY
OP,
SAVE YOUR MONEY
All good thoughts. Many thanks.
The Sicilian
According to this tire calculator, you need at least 9" wide wheel and the 18's are only 8" wide.
Just plug your numbers in.
http://www.1010tires.com/TireSizeCal...?action=submit
Guest
Posts: n/a
Great find! Well that settles that. 245/45/18 size tires are the ones we have to stay with.
AZ Community Team
Stay Out Of the Left Lane
Received 1,237 Likes
Depends on if you want to follow the rules or not.
Back in 2004 based on the feedback on this site - I put 255/40 R17 Goodyear Eagle F1 GS-D3 on my OEM 8.0" rims. Ran them for years without a problem and loved them. Today I have 245/45 R17 Bridgestone Blizzaks on my OEM 8.0" Type-S rims. I got a good deal on these tires otherwise I would run narrower (better in the snow).
For the Summer months I still have my 8.5" A-Spec Rims and am running 255/40 R18 only because I did not want to spend the extra money for the 265s or deal with the ride quality of a lower (35) profile tire. If you read the other thread, the member said it could be done and showed that it could be done. Was it recommended by the tire manufacturers, no but it is his car and he modded it the way he wanted to. Is it smart......... as you read the thread, you will see the varying opinions.
So in short 235, 245 and 255 widths will fit an 8.0" wide rim. I've had personal experience with all three. Would I go to a 265 width, probably not.
To the OP just make sure you use the tire calculator with the profiles in mind to keep the overall dims within range of the OEM set up
B A N N E D
as far as fitting a wider tire, with a good quality tire machine, you probably could stuff a 305 on a 8.0" rim though, going to act like a ballon, and ride the center tread out REAL FAST, but it will fit though (let alone a narrower contact patch probably too, due to the edges curving up)
and as far as keeping the stock diameter in check
merc009
10-03-2015 12:59 AM
