20x9 +35 offset, H&R, TPMS
Hello everyone, I have my car lowered on H&R sport springs and I want to get vossen cv2s in the size 20x9 with +35 offset but I'm worried about fender rolling, I truly don't want to roll my fenders. Does anyone know how it would work out and if I will encounter any problems? Lastly I'm getting the rim/tires used so should the tpms system still work or do they need a re-build(used rims/tires coming off another 4g TL)? And pics would be great if you have any. Thanks for all your replies and thanks for looking.
No fender work. There are a ton of members running this setup with no issues. What are the tire specs? Browse thru the photo gallery. I'm not sure about the tpms though. You would need to ask the seller that. Should be compatible though but you will need to swap out the tpms from your OEM wheels or buy another set.
Rolex I am running the exact setup on Tein H springs. No fender rolling but my rears have a slight camber. You will be fine all around. For picks check here https://acurazine.com/forums/4g-tl-photograph-gallery-296/dreduo-build-890886/
I enjoy the set up. The TPMS may fit, it all depends on how the wheels are made. Go to the manufacturer website. Info should be there if the wheel accepts TPMS. Make sure to post pics once everything is on.
DreDuo (07-23-2013)
neuronbob
23
07-16-2019 10:48 AM
calrow
05-03-2017 10:21 PM
