2010 6MT AWD Suspension Question
Hi Guys,
I'm new to the forum and I'm new to anything that has to do with suspension setups.
So few weeks ago I did a DIY H&R suspension setup which I found pretty easy to do even though removing the back sit was quiet a hassle.
I just did my alignment and results came out as follows:
Fronts: everything is good and within spec -1.3 camber on both left and right. Toe and Caster were dead on perfect.
Rears: -2.7 on the camber while toe and caster is dead on.
I should also mention that i'm running 20" Ron Jon Legends Type 2.
I can already see that there is about an inch of unused tread on the rear tires.
I've noticed there are two kits available on XLR8's website:
1) 35623
2) 38623
What is the difference between the two and which one do you guys suggest I go with?
Appreciate your suggestions
1) 35623
2) 38623
There are two kits though..... which one did you go with?
1) Smart Arm Adjustable for $50 each
or
2) Camber / Toe kit for $150 each
I guess I don't want to spend the extra money if there is no reason for it.
Thanks again
or
Thanks again
Number 2. The rear camber kit is all you need to address your issues. You should PM them to get a better price or shop around and check the black market. I was fortunate to find one for 220 shipped BNIB from a member here.
