20 x 10.5 on 4th gen TL
7th Gear
So I'm planning on getting some rims for my 4g TL but the problem is that the rims is 20x 10.5 on the 2 rear tires and also they are 5x114, as you guys know my wheel pattern is 5x120, so if I were to put the adapters for a wheel that wide would there be a problem? PLEASE HELP! 😩
ElCharlie (03-21-2014)
The Original Shawdy
It's possible if they weren't 5x114. There's a few members running 20x10.5 but the correct lug pattern.
Cyberathlete101
the width of 10.5 is not a problem.
but the 5x114.3 bolt pattern is a big problem.
using adaptor to fit a 5x114.3 wheel is possible, but no recommended.
you may experience vibrations and other issues.
also, using adaptor to fit would mean your wheels will stick out further, unless your wheel originally comes with a very high offset +50 or more. you would have clearance issues.
so at the end...all the trouble, time and money you have to spend wouldn't be worth your time.
my 2cents.
GL with your ride!
my 2cents.
GL with your ride!
emailnatec
29
09-28-2018 04:27 PM
GWEEDOspeedo
01-15-2016 10:39 PM
RSpyder
09-30-2015 12:46 AM
