19x8 +35 19x10 +30 tire size. need opinion
19x8 +35 19x10 +30
what size tire should i run for front and rear?
need opinions
need opinions
Hey guys I have a 09 Tl with tech… I know my car is fwd I also know that im not "suppose" to run staggarded wheels on a fwd that isn't my question on concern my question is what offsets are you guys close to cause wheels I'm looking into come 19x9 + 22 and 19x10.5 + 22 and one with a 4g please shine come light please just want flush figment thAnx
2. 19x10.5 +22 is pretty high. your going to have to look into cambering. which consist of good suspensions, and camer kit.
Rolling diameter and wheel width wise you probably want
245/45/19 F
275/35/19 R
However I do not know if that offset can accommodate the proper tire sizing.
Yeah, but I dont think stock is a 18x8 wheel.. or is it? If thats. Truthfully, either will do.. Depending on how low you are would determine if id run a 35 or 40 series sidewall... Do the wheels have lips? Are you lowered?
hahah, seriously... heres my opinion on wheels w lips.. Id stay w a 35 series sidewall.. 40s only look good on wheels w lips if its like a stretched look, which i dont think ur going for. So run either a 235 or 245/35/19 in the front and a 255/35/19 in the rear.. You should be good to go with that set up and should be clear of any rub... Got any pics of the wheels?
6G TLX-S
^^^^^ The TPMS sensors aren't going to fit for these rims, since the valve stem is smack in the mid section of the rim body.
You simply stick the valve stem portion through the hole and there should be a cap that you use to screw it down tight. No it doesnt matter that it is slanted. Mine were and I had no issues. GL and lemme know if that made sense
oyayjoe
09-12-2015 04:40 PM
cammy5
09-04-2015 11:26 PM
nuldabz
09-03-2015 05:49 PM
