19'' work staggered Schwert SC1
saw a great deal around town, don't want to miss the deal, but not sure about the rear setup.
19" Works Schwert SC1 wheels
Size:
19x8.5 ET32 5x120
19x9.5 ET35 5x120
Finish:
BP Black Polish with polish lip
Tires:
Goodyear Eagle GS-D3
235/35/19
265/30/19
Any thoughts about the wheels and tires set up? I wonder how it will be with the front +32 offset and that rear tire 265/30/19 profile. They were taken off from a bimmer though. what size is good for the spacer for the front?
Size:
19x8.5 ET32 5x120
19x9.5 ET35 5x120
Finish:
Tires:
235/35/19
265/30/19
2012 TL SH-AWD
If the wheels coming from a BMW they have same bolt pattern 5x120mm but they're not hub centric or have different size so you will need a ring adapter. The hub centric for TL is 64.1. Also do you have a SH-AWD or FWD? Is not recommended to use staggered setup on awd system even tho I've seeing couple members doing it.
yah I have an awd, mind I ask why is not recommended? For the ring adapter, is that mean simply i need a hubcentric ring? what would be the right size if it came off from an e90?
Oops, I thought it the wrong way. I knew it will stick out a bit. They are 19'' wheels with thinner tire and my car is not lowered, so i thought so far it's ok but please correct me if I am wrong. I do plan to go lower after with spring but now I am just thinking of the possibility with these sets now.
6G TLX-S
^^hope it works out for you - i think the only snag might be the larger size 14mm acura wheel studs- tire size if you are awd would be better suited for
225/35/19 front and 265/30/19 rear
or
235/35/19 front and 275/30/19 rear to keep the over tire size the same
or
no, if your awd, your better suited with all same size tire all around.. 245/35/19 or even 255 at best.. as long as you keep the tire size all the same, your awd system wont be thrown off.
^ Same size tire front and rear is ideal for awd- but being thats its staggered rims- the idea size for a 235/45/18 stock tire is a 265/35/19 to keep revs and speedometer the same. Even if he ran say a 245/35/19 all around the difference of fitting it on a 8.5 and 9.5 would be greater than just running the staggered tire sizes (the more a tire is stretched on the shorter it is)
Tire 1 - 235/30R19
Section Width: 10.82 in 275 mm
Rim Diameter: 19 in 482.6 mm
Rim Width Range: 9.5 - 11 in
Overall Diameter: 25.49 in 647.44 mm
Sidewall Height: 3.24 in 82.296 mm
Radius: 12.74 in 323.59 mm
Circumference: 80.07 in 2033.7 mm
Revs per Mile: 816.0
Tire 2 - 275/30R19
Section Width: 9.25 in 235 mm
Rim Width Range: 8 - 9.5 in
Overall Diameter: 25.47 in 646.93 mm
Sidewall Height: 3.23 in 82.042 mm
Radius: 12.73 in 323.34 mm
Circumference: 80.01 in 2032.2 mm
Revs per Mile: 816.6
Tire 1 - 235/30R19
Tire 2 - 275/30R19
Tire 1 - 235/30R19
Tire 2 - 275/30R19
Tire 1 - 235/30R19
Tire 2 - 275/30R19
running staggered on a sh-awd will only result in under and oversteer from what i know.. i personally dont have a awd.. but from what i read throughout the year.. its just best to have it all run the same size.. again, i recommend 255/35 all around..
i think you got your info backwards.. you might want to check what i highlighted in red.
mada51589
05-03-2022 08:54 PM
ahsm
09-09-2015 08:35 AM
nuldabz
09-03-2015 05:49 PM
