19" Vossens - Will these fit my 4G?
wheel experts, just wondering if this set of vossens will fit my 4G.
FRONTS 19X8.5 +30 OFFSET
REARS 19X10 +36 OFFSET
Bolt pattern should be fine - 5x120
hub - 72.6 which i found a converter for our 64.1
I just wanted to make sure the offset would be ok.
let me know.
let me know.
Below are the two differences between 225 and 235
Although since you are a sh-awd, you will need to keep the rolling diameter the same on all sides.
i would suggest to do 245/35/19 on all sides.
that will keep your rolling diameter the same on all sides.
if you dont care about performance then you can just go with the suggested size.. but personally i would not run a 225 on this 4400 lb car..
i do run a 235/30/20 and 255/30/20 on my car but its because i have very low offset.. need small tires so i can turn and also to make the rears fit without camber.
jproxx (10-03-2012)
trust me.. if i can do a 20x9.5 +12.. he can def do a 19x10 +36 easily..
btw i had to shave my fenders.. but i dont have to camber my wheels
^^AAAaaand it looks hot too!
emailnatec
29
09-28-2018 04:27 PM
