Washer jets not working
Old Dec 6, 2016 | 10:42 AM
ABDomega's Avatar
2011 SH-AWD 6MT
When I pull the washer stalk, no fluid comes out though I can hear a pump making the sound. At first I thought I ran out of fluid so I filled it up but it only took 1/4 gallon and I tried again and still nothing. The wipers move, the pump makes a sound but nothing comes out. It's cold outside but not that cold, yesterday it was 40F and I still have this problem. I checked the nozzles and they're clean from what I can tell. The car is garaged at home and work.
I recall reading on the 3G board about a fuse. Any ideas?
EDIT: I'm starting to think the hose is bound/crimped or disconnected. I'll start there but I'm not sure how that would happen.
Old Dec 6, 2016 | 11:19 AM
me thinks so too
or clogged
Old Dec 6, 2016 | 11:40 AM
JT4's Avatar
JT4
CTSV,TL, Audi Q7 & A5SB
I don't think a hose is disconnected because if it was wouldn't you notice washer fluid under the car? I also don't think it's a fuse since you can hear the pump making noise.
I think it's crimped or clogged somehow.. Check the actual washer nozzles also to see if they look dirty or clogged.
Old Dec 6, 2016 | 10:32 PM
grctampa's Avatar
9th Gear
Check the nozzles, clear them with a straight pin. I've had this problem with other vehicles.
Old Dec 10, 2016 | 07:59 PM
ABDomega's Avatar
2011 SH-AWD 6MT
The nozzles are not clogged, I checked them again. I checked under the hood and found this plastic hose joint had become disconnected from one of the tubes. I reconnected it and it worked for like 3 seconds then became detached and fluid shot out of it. Can anyone check if they have any clamps on this piece? Mine is greased up and I'm not sure why it became undone and continues to do so just with use.
Old Dec 10, 2016 | 08:21 PM
Lee C's Avatar
Are you able to put a small zip tie on the hose?
Old Dec 10, 2016 | 09:41 PM
dregsfan's Avatar
Sounds like either the tube or the joint is clogged.
Old Dec 13, 2016 | 08:36 AM
ABDomega's Avatar
2011 SH-AWD 6MT
I could, but why is it so loose in the first place? I don't use my washers frequently. Maybe that's why.
ABDomega's Avatar
2011 SH-AWD 6MT
Not clogged at all. When the tube is connected the water flows as normal. The pressure is popping the L connector off.
Old Dec 13, 2016 | 08:38 AM
me thinks you're worrying too much about the cause.
put a clamp on it, or zip tie!!
Not using the washers wouldn't cause the line to fall off, just FYI
also, you mentioned that yours is greased up.
so, possibly dirt and grime and grease could have wedged itself between the hose.maybe the grease helped push the line off
Wipe off dirt, grime, grease and clamp it
Old Dec 13, 2016 | 08:52 AM
But why?
