Vibrating sound from speaker
I often hear a vibrating sound from the passenger door speaker. This only happens when I play the radio - I don't hear it with CDs. It sounds like a cracked/broken speaker. The dealer said it was the amplifier, which they replaced, but the problem continues. They did not bother to look at the speaker itself, they said they ran a diagnostic test.
Any thoughts? Could it just be poor radio reception? But why only on the passenger side?
I have noticed too that at a certain frequency (don't know how many hz exactly) the passenger speaker vibrates and it sounds awful. The dealer you went has no clue about physics. Vibration occurs when the frequency of the source that causes the vibration matches the frequency of the material of an item... in very simple terms. A simple fix for me was to remove the panel and speaker and add a bit of tape behind the edge of the speaker, therefore changing the frequency of the material of the speaker. Since I removed the panel I also fixed that annoying rattle on the window switch panel of the passenger door too, using some more tape under neath it.
BTW, a dealer who throws parts on a car hoping that will fix anything and then saying they did a diagnostic test... oh! please! haven't we all heard that bull before...
does this sound like your issue? -
Service Bulletin 10-027
Applies To: See VEHICLES AFFECTED August 3, 2010
Door or Rear Shelf Speakers Rattle, or Sound Is Distorted SYMPTOM WARRANTY CLAIM INFORMATION
There is a rattle or distorted sound in at least one of the speakers in the doors or the rear shelf.
The normal warranty applies.
NOTE: There are separate warranty numbers depending on which side of the vehicle you begin. For example, if you replace the left front speaker, then the right, use OP# 012100 and combo code A to file your warranty claim.
PROBABLE CAUSE
The speaker damper is faulty.
VEHICLES AFFECTED
2008–09 RDX with navigation – ALL
2010 RDX 2WD with navigation – From VIN 5J8TB2...AA000001 thru
5J8TB2...AA001087
2010 RDX SH-AWD with navigation – From VIN 5J8TB1...AA000001 thru
5J8TB1...AA001769 2009 TL – ALL
2010 TL 2WD without navigation – From VIN 19UUA8.2.AA000001 thru
19UUA8.2.AA002612
2010 TL SH-AWD without navigation – From VIN 19UUA9.2.AA000001 thru
19UUA9.2.AA001466
2010 TL 2WD with navigation –
From VIN 19UUA8.5.AA000001 thru
19UUA8.5.AA006708
2010 TL SH-AWD with navigation – From VIN 19UUA9.5.AA000001 thru
19UUA9.5.AA002870
CORRECTIVE ACTION
Replace the affected speakers.
PARTS INFORMATION
Speaker:
RDX, TL without navigation – P/N 39120-STK-A12 TL with navigation – P/N 39120-TK4-A51
RDX
Location
OP#
Description
FRT
Front Door Speakers
012100
Replace left front speaker.
0.2
12100A
Add right front speaker.
0.2
0121A2
Replace right front speaker.
0.2
12100A
Add left front speaker.
0.2
Rear Door Speakers
013100
Replace left rear speaker.
0.2
12100A
Add right rear speaker.
0.2
0131A8
Replace right rear speaker.
0.2
12100A
Add left rear speaker.
0.2
TL
Location
OP#
Description
FRT
Front Door Speakers
012100
0.2
12100A
0.2
0121A2
0.2
12100A
0.2
Rear Door Speakers
013100
0.2
12100A
0.2
0131A8
0.2
12100A
0.2
Rear Shelf Speakers
0141A1
Replace one speaker.
0.6
12100A
Replace second speaker.
0.2
Failed Part: Defect Code: Symptom Code: Skill Level:
P/N 39120-TK4-A51 03217
03220
Repair Technician
© 2010 American Honda Motor Co., Inc. – All Rights Reserved BTB 44245 (1008)
1 of 2
CLIENT INFORMATION: The information in this bulletin is intended for use only by skilled technicians who have the proper tools, equipment, and training to correctly and safely maintain your vehicle. These procedures should not be attempted by “do-it-yourselfers,” and you should not assume this bulletin applies to your vehicle, or that your vehicle has the condition described. To determine whether this information applies, contact an authorized Acura automobile dealer.
DIAGNOSIS
Do the speaker check mode to isolate the faulty speaker(s):
1. Turn the ignition switch to ON (II).
2. Make sure the audio system is turned off.
3. Push and hold the No. 1 and No. 3 preset buttons.
4. While holding the preset buttons, push the PWR knob to on.
5. Release the buttons and the speaker check mode begins. A test tone should sound from one speaker as indicated on the display.
6. Each time you press the SEEK/SKIP CATEGORY button, the test moves to the next speaker.
7. The speaker check mode ends when you turn the audio unit off, or turn the ignition switch to LOCK (0).
REPAIR PROCEDURE
Replace the applicable speaker(s):
• Refertotheaudiosectionoftheappropriateservice manual, or
• Online,underSearchbyVehicle,enterkeywords SPEAKER REPLACE and select Speaker Test/ Replacement from the list.
2 of 2
10-027
can find here:
AcuraZine Community > AcuraZine TL Community > Fourth Generation TL (2009+)
>>> 4G TL Service Department: Questions & Answers- CHECK HERE FIRST! <<<
PROBABLE CAUSE
VEHICLES AFFECTED
5J8TB2...AA001087
19UUA8.2.AA002612
19UUA9.2.AA001466
19UUA8.5.AA006708
19UUA9.5.AA002870
CORRECTIVE ACTION
PARTS INFORMATION
Speaker:
RDX
Location
OP#
Description
FRT
Front Door Speakers
012100
0.2
12100A
0.2
0121A2
0.2
12100A
0.2
Rear Door Speakers
013100
0.2
12100A
0.2
0131A8
0.2
12100A
0.2
TL
Location
OP#
Description
FRT
Front Door Speakers
012100
0.2
12100A
0.2
0121A2
0.2
12100A
0.2
Rear Door Speakers
013100
0.2
12100A
0.2
0131A8
0.2
12100A
0.2
Rear Shelf Speakers
0141A1
0.6
12100A
0.2
03220
Repair Technician
1 of 2
DIAGNOSIS
REPAIR PROCEDURE
2 of 2
10-027
can find here:
nismod05 (01-12-2013)
SinCityTLX
20
10-19-2015 11:23 AM
polish_pat
09-25-2015 12:24 PM
4drviper
09-23-2015 09:00 PM
